Solder Flux paste UV50vs Uv80
Home Forums Electronics in the Workshop Solder Flux paste UV50vs Uv80
  • #768015
      What on earth is the difference between these two grades ?
      [ please resist the temptation to answer 30 ]
      It looks like I will need to start soldering some SMD … and I have seen an impressive demonstration using the ‘Mechanic’ brand of Flux … but I have found nothing to explain the difference between UV50 and UV80
      Education would be much appreciated
      Refhttps://youtu.be/omR7QE8H82w?feature=shared
      Grindstone Cowboy
        @grindstonecowboy
        Hate to say it, but it looks like it might be as simple as the size of the tin – I’ve found reference to the UV80 being sold in an amount of 80ml here.
        Hope this helps – looking at other parts of that site, the naming convention relating to amount seems a bit random.
        Rob
        Links to https://radiodetali.com.ua/ua/product/flyus-pasta-mcn-uv80-80ml-13130
        #768071
          If true, Rob … that will be hilarious
          When I stop screaming !
          https://www.britishmuseum.org/blog/10-things-you-may-not-know-about-scream
          #768074
            The details in this ebay listing suggest that you are correct, Rob
            https://www.ebay.co.uk/itm/394983613840
            You may have saved my sanity !
            Grindstone Cowboy
              @grindstonecowboy
              Glad to be of service – maybe we should have enlisted the Fluxite Quins to help 🙂
              Rob
              Links to https://worldradiohistory.com/UK/Practical-Mechanics/40s/Practical-Mechanics-1941-10-S-OCR.pdf
