Soft soldering aluminised tube ?
Home Forums Materials Soft soldering aluminised tube ?
  • #30087
    Tim Stevens
      @timstevens64731
      What preparation, what flux?
      Tim Stevens
        @timstevens64731
        I need to solder a new tube into a vehicle cooling system – steel tube soft soldered into a brass angle-piece. My client has obtained aluminised tube (exhaust) which is the right size and shape, but will it solder, and if so, how?
        The overlap of tube to boss is about 25mm (one inch).
        Thanks in advance for your advice
        Regards, Tim
        #512516
        Dave Halford
          @davehalford22513
          I would remove the plating in the joint area and fully tin the area before assembly.
          #512536
          Keith Hale
            @keithhale68713
            Hi Tim
            Simply use a liquid soft soldering flux SPECIFICALLY for aluminium. Follow this with 60/40 tin/lead solder.
            Or you could adopt a cheaper option of using a soft solder wire with a flux core suitable for aluminium. It's cheaper because you're buying less flux and in a form that can be sent through the post at minimum cost.
            You know where to find both items!🤔
            What puzzles me is why you didn't ring them in the first place. One phone call and you get the advice and materials.
            Best wishes
            Keith
          Home Forums Materials Topics
