Twice recently I have had unexpected difficulty soft-soldering small brass and copper components.
I was using plumber’s paste flux, and flux-cored solder.
The electrical-grade solder seemed reluctant to melt, and just did not want to wet the metal properly, making hard a task I should have found simple and very satisfactory.
Many different plumbers fluxes and they are all incompatible with electrical fluxes. Never mix different fluxes!
Is it possible the flux, either the paste in the tin (which is old but I don’t know how old) or inside the solder, has gone off with age?
Or that the solder itself has become too oxidised to work? (It is a bit grey.)
Yes, plumbers flux, can go off, and yes dirty solder gives flux more work to do and increases the chance of failure. Shouldn’t be a surprise that a flux that’s lost some of it’s power is more likely to fail than one in tip-top condition. Electrical flux can also ‘go off’. How long a flux takes to ‘go off’ depends on the particular chemicals in the flux and how it is stored. Individual reports of long life are pretty much hearsay, not worth much unless they identify the specific product, the condition of the packaging and the nature of the temperature and humidity cycles it was stored in.
From a chemist’s point of view designing a flux is complex. He has to find a chemical, or mix of chemicals, that melt, clean, and seal out air when heated, and then dissipate without leaving too much nasty residue behind. Any residue should be easy to clean, ideally water soluble, and non-toxic.
Cost matters. Cheap is OK for plumbing because it can tolerate a lot of dirt, electrics can’t. Soldering electronics with plumbers flux is a disaster, because the acid residue attacks every delicate metal surface within range – several feet! Soldering electronics requires a much higher standard of cleanliness because the clean resin based fluxes used are weak compared with the cheap rough, tough chemicals used by plumbers. Even though it’s reassuringly expensive electrical solder high-risk for plumbing jobs. In both cases the flux is wrong for the job.
The chemist also has to consider the metals being soldered. Fluxes such as Zinc Chloride, Sodium Phosphate and Ammonium Chloride work well on Copper, but are a poor choice for Brass, for which Sodium Borate is more suitable. Iron, Nickel, Steel, Bronze, Aluminium and Zinc are another story. Doesn’t help that another chemist alters the ratio of Tin and Lead in soft-solder to suit particular types of work, and the flux has to be formulated to deal with that too.
Old-time fluxes such as Sodium Carbonate, Potassium Carbonate, Calcium Oxide and Charcoal aren’t ideal for various reasons. Many others are off the list because they are costly, toxic, have poor shelf-life or some other disadvantage. Killed Spirits / Bakers Fluid was the first ‘easy to use flux’; compared with earlier methods it’s semi-fool-proof! Killed Spirits is an easily made acid solution of Zinc Chloride, long-lived, but it tends to leave muck inside the joint. Being very corrosive makes the spilled liquid a pesky nuisance, so the chemist developed pastes, which are also easier for the workman to apply. The chemical used to hold the paste together this might degrade over time, making the flux action patchy.
In the workshop, customers like to keep it simple by buying a brand-name flux that works on almost everything, possibly not aware that the contents must be a compromise. Fortunately the chemist can get quite close to ideal by blending different flux chemicals so that – within limits – one or other will do the job when heat is applied. Some of the chemicals are more stable than others, but note that all fluxes melt at below soldering temperatures, and can’t be totally stable over time. They may also absorb water, leading to poor performance or separation of the mix. Discerning customers study the catalogue, looking for a flux well suited to the job. Using a suitable new flux for a Lead Free soldering job is a better bet than relying on a rusty tin of government surplus flux picked up cheap in 1952 and race-tuned for lead solder only!
By all means try ancient flux on a low-risk job as Nigel has done, hurrah if it works, because that saves a few bob. Don’t rely on it though! Unwise I think for a beginner to attempt to solder a complex boiler using unknown materials because the cost of failure is unpleasant!
I think Nigel’s main problem is mixing plumbers flux, which might be ‘off’, with electrical solder, which might also be ‘off’. So, either approach this as an electrical soldering job without plumber’s flux, or – probably more practical – use plumber’s flux with plumber’s solder. And clean all the metal before starting.
By the by, my other hobby provides the gear for electronic soldering and I’ve attempted to apply it to mechanical engineering with low success. 60/40 and high Tin solders both struggle. Not sure why. I guess my irons don’t put enough heat into slightly larger joints to melt the solder before the rosin flux burns off. The biggest is a 140W Weller Solder Gun. Conversely my blowlamp flames are too high temperature and burn the rosin off too quickly. The characteristics of electrical solder and irons that make them good for electronics, don’t good seem suitable for general purpose work.
