Soft Solder
Soft Solder
  • #114785
    Alan Church
      @alanchurch85600
      Whats the best way to attache the very small hand rail stanctions as used on Gauge 1 Lococ's? The ones I have are not threaded and I have been told to soft solder them in. As you known various solders have a wide range of melting points. So what's the best solder, or should I arladite them in.
      Any advice greatly recieved
      Alan Church
        @alanchurch85600
        Hand rails Gauge 1 loco
        #114791
        CuP Alloys
          @cupalloys
          Hi Alan,
          The easiest soft solder to use is 60/40 tin lead.
          Melting point 187deg C. Free flowing producing small neat fillets.
          For small joints as described use paint.
          It is 60/40 tin lead powder mixed with a flux and binder. Paint it on the components, assemble and heat gently. Wash with water.
          Product is readily available.
          regards
          keith
          #114805
          michael howarth 1
            @michaelhowarth1
            Alan…..a short while ago on the Gauge 1 forum someone gave this advice. If the stancions have have a small spur on the underside, then a 10 or 12 BA thread can be formed and the stancion can then be nutted on. I think the correspondent on the G1 forum backed this up with a touch of solder to hold the nut in place although if you manage to get a good thread I am sure Loctite or similar would do the job. I obtained my stancions from Walsall Models and they have a spur.
            Mick
            #114843
            Russell Eberhardt
              @russelleberhardt48058
              Posted by CuP Alloys on 19/03/2013 20:56:32:
              Also available as solder paste in syringes. It is easy to deposit small quantities without waste or mess.
              Russell.
