The Field Marshall comments bring back happy memories of when we had a couple of those tractors.
We always used to start ours on the handle, they have a very simple de-compressor mechanism to allow you to crank it easier, there is a threaded groove on the outside of the flywheel into which a roller lever engages to pull a cable that opens the de-compressor valve. you have to be carefull to note which groove you put it in, because that dictates how many turns you crank it before it drops off the edge of the flywheel and hits full compression. We used to do three turns and then Bang, Bang, BAng…………
12 bore blank cartridge starting was reserved for showing off to friends, my dad did this once and forgot to remove the plastic bucket that kept rain water out of the exhaust chimmney. It flew about 20 feet in the air and came back down and landed perfectly over his head, I wished I had a camera handy that day !!
It was quite easy to accidentally start the two stroke engine backwards if it kicked back, you then had one forward and three reverse gears. Our Fowler VF crawler was almost the same, but that did run the opposite way to the Field Marshall engine.
Phil
Edited By Phil P on 19/06/2020 10:18:46
