Sodium Nitrite for case hardening?
Home Forums Model Engineer. Sodium Nitrite for case hardening?
  • #37612
    IanT
      @iant
      What is the process mentioned in ME Postbag 4467?
      IanT
        @iant
        In the latest edition of ME (4467) there is a letter in the 'Postbag' section, entitled "Patents worth Pondering" (by Andre Rousseau) in which he mentions a German WW2 invention to case harden metals using a "simple" process using a sodium nitrite solution. Apparently the details are in a book Andre mentions but that wasn't too helpful in practice (as I don't have a copy)..
        I've been thinking about case-hardening some small parts recently but currently have no Kasenit or similar, so would need to purchase them. Does anyone know any more detail about this process and whether the materials are readily available (and as safe to use as suggested)?
        IanT
        #133056
        Sub Mandrel
          @submandrel
          My thoughts exactly… a bit like "I don't know why people don't run their cars on water, it's simple enough".
          Having played with potassium nitrite (amongst other chemicals as a teenager, I'm not convinced sodium nitrite is necessarily safer than Kasenite).
          Clive Foster
            @clivefoster55965
            A few minutes internet searching turned up the text of Harry Sevens book Hitler's Suppressed and Still Secret Weapons Science and Technology on Google books.
            The relevant bit seems to be :-
            claimed to produce a nitride coating up to 0.5 cm thick with a hardness of up to 1,800 Vickers is as follows. The steel is heated to 600 degrees C and quenched in 30% aluminium sulphate solution which etches the surface. When cold the steel is packed in powdered charcoal and heated to 750 and on reaching this temperature is removed from the charcoal and quenched in a 15% sodium nitrite solution at 35°C. The method is good for drills and silicon steels.
            Nothing very remarkable there. Basic carbon pack case hardening without accelerant but preceded by an etching step which, presumably has a similar effect to an accelerant in increasing the speed and depth of carbon penetration. Sodium nitrite quenching is an established practice said to reduce the chances of cracking and distortion as compared to plain water whilst improving steel properties. So, in principle, no different from all the other nostrums in the carbon, additives in the quench versions. Far as I can see all variations do what is said on the tin if you do it right but the structural variation of steel is incredibly complex in detail so there is much to be gained if you get the process control right. In the home shop simple, repeatable and tolerance of ahem "variable" process control is much more important than uber high performance.
            Skimming the book Mr Stevens seems a less than reliable source. Basically reporting what he has been told, what sounds right and so on. Daily Mail science at best. The official document quote should not be taken at face value either. Much face covering, position protecting and politics going on as the folk who approved the final text certainly did not understand the technologies and the implications. In my experience getting accurate technical assessments through the military support 'crats is nigh on impossible!
            #133078
            Russell Eberhardt
              @russelleberhardt48058
              Posted by Clive Foster on 19/10/2013 16:06:50:
              Definitely sounds like "snake oil" to me. I'll stick to my old tin of Kasenit.
              Russell.
              #133084
              Muzzer
                @muzzer
                Stub, presumably like me you played with nitrate to make bangs, not nitrite? Although they are both oxidants, nitrite is highly hygroscopic, even more than nitrate, so any "mixtures" you made would soon become very wet.
                The biggest bang I ever made was actually a lot simpler than the classic chemical mixtures, even the ammonium nitrate/aluminium (poor man's Ammonol?). I took a 50 gallon oil drum, added a pint of water and screwed the cap back on, then lit a bonfire under it. When the ends started to bulge like balloons, I reckoned it might be sensible to retreat to a safer distance. This turned out to be a good instinct. I never found the end of the drum that flew off. And the drum itself ended up about 50m away. Funny thing was, I was living in Northern Ireland at the time, during The Troubles. I made myself scarce before Plod arrived!
                Could have cut someone in half. A vivid illustration of the energy that can be stored in compressors, boilers and other pressure vessels and the importance of ensuring they are correctly rated and tested.
                Merry
                #133086
                Sub Mandrel
                  @submandrel
                  At least my fears that it was using a bath of molten sodium nitrite were unfounded!
                  Clive Foster
                    @clivefoster55965
                    Russell
                    Carbon pack case hardening can be surprisingly deep given the right steel and plenty of hot time for the carbon to migrate. However I suspect that Mr Stevens was unable to appreciate the difference between 0.5 cm and 0.5 mm. 20 thou or so is easily achieved. We could also quibble over the confusion between case hardening and nitride coating. Sodium nitrite at 35% concentration in water is not going to do much for the second or so period over which the steel surface remains hot enough for interesting things to happen.
                    But the guy is a writer so one has to pitch ones expectations at the right level.
                    #133145
                    IanT
                      @iant
                      That sounds like a "No" to 'is it simple and safe' then Clive. Thank you for digging the detail out.
                      Plan B is to pack them into a cast-iron junction box (3" circular type) with some chopped up shoe leather. seal it up with some kind of fire cement (trip to local hardware shop required) and cook it all in my garden incinerator for a few hours next time I have a bonfire (early November is always seems a good time to do this kind of thing!)
                      Anything better (than leather) to use?
                      IanT
                      #133150
                      NJH
                        @njh
                        Ian
                        I'm not too sure about the "chopped up shoe leather" – maybe a bit hit and miss? I notice that there is some case hardening powder listed at a well known on -line auction site HERE which would probably achieve more predictable results?
                        Norman
                        #133198
                        IanT
                          @iant
                          Thanks Norman,
                          I also found this thread on this forum which gives quite a bit of information on 'home-brew' solutions.
                          IanT
                          #133207
                          Clive Hartland
                            @clivehartland94829
                            Hello Ian, you found the messages about home brew case hardening, I hardened some gun trigger parts and got a good hard skin which has lasted many years and has not worn just using the leather, I would add some powdered charcoal. about 30% of the volume to the pieces of leather. I found it best to close the box and keep a good ,more than cherry red heat for some time to get the depth of hardening. The box can just have a loose lid not totally sealed but well packed. It will be OK if it is not disturbed while firing. If no air can get to it the surface comes out clean when quenched. Throw the whole thing in some salty water.
                            #133209
                            Russell Eberhardt
                              Something that hasn't yet been mentioned is the time required. With a typical case hardening compound such as Kasenit or even just a mixture of charcoal with about 1% of washing soda, the case will be formed at a rate of about 0.008" per hour. So you need to decide how deep a case is needed and then decide on the time the work has to be kept at red heat. It is best to let it cool naturally and then clean and reheat it to "cherry red" and quench to harden the case. Quenching it still in the tin is poorly controlled and may not cool it quickly enough.
                              Russell.
                              #133210
                              Russell Eberhardt
                                Russell.
                                #133229
                                IanT
                                  @iant
                                  To be honest guys, at this stage, I simply want to experiment a bit (before I try it on any more serious work and b***** it up). I also like the idea of coming up with my own (simple/cheap) homebrew solutions whenever possible.
                                  I have been thinking about adding some charcoal to my 'old boots' and have read somewhere that coconut shells make really good charcoal for this purpose (walnut shells were mentioned in the other thread – but I don't like walnuts!). So as SWMBO generates lots of empty coconut shell husks from her bird feeder, these have been quietly accumulating in the Shed. They recently got broken up and now live in an old Tate & Lyle tin (rescued for the purpose) awaiting my first attempt at making "special" charcoal.
                                  It may well be that I will end up buying the proper commercial stuff but in-between I will have lots of fun with bonfires and sticking things in them (just like I did a long time ago). Last of the Summer Wine anyone?
                                  IanT
                                  #137779
                                  Cyril Bonnett
                                    @cyrilbonnett24790
                                    I have been looking to case harden a couple of pieces of mild steel and have been reading quite a few web sites about the processes involved, this one is quite good and informative
                                    Cyril
                                    #137796
                                    Russell Eberhardt
                                      Tubal Cain's book "Hardening, tempering & heat treatment" (Workshop Practice Series) has a chapter on case hardening which explains the various processes very well. At about £7 from Amazon it's good value.
                                      Russell
                                      #137800
                                      MICHAEL WILLIAMS
                                        @michaelwilliams41215
                                        (1) I read about this process for case hardening small parts in an old book but have not yet tried it :
                                        Thickly coat the component with candle smoke .
                                        Bring component to red heat for one or two minutes .
                                        Repeat up to three times .
                                        Quench .
                                        (2) A process which does work but requires a rather excessive level of skill is to engulf the component in a yellow oxy acetylene flame and bring to red heat .
                                        Soak component at red heat in the flame for several minutes and then quench .
                                        Yellow flame is carbon rich and oxygen deficient and quite effective for carbonizing at least surface layers of components .
                                        (3) All Sodium Nitrite does in a quenching bath is to soften the quenching action a bit – like using a surface layer of oil or using brine . No chemistry involved .
                                        Regards ,
                                        MikeW
                                        Edited By MICHAEL WILLIAMS on 14/12/2013 10:45:45
                                        Edited By MICHAEL WILLIAMS on 14/12/2013 10:47:19
                                        #137802
                                        Ady1
                                          @ady1
                                          The simplest one I can recall is someone who had a motorbike part which kept failing
                                          So they made a replacement bit out of steel, heated it up then quenched it quickly in-and-out of motor oil and left it to one side to cool off
                                          The part had been fine ever since and no more failures
                                          #137808
                                          John Stevenson 1
                                            @johnstevenson1
                                            Definitely 'bling ' reporting if they are quoting 0.5cm thick.
                                            Only the BBC and dressmakers use cm.
                                            #137810
                                            Clive Hartland
                                              @clivehartland94829
                                              The Sodium Nitrite quench would just be the same as a Brine quench, it softens the impact of the cooling and would stop surface cracking.
                                              #137815
                                              Clive Hartland
                                                @clivehartland94829
                                                The bit for the motorcycle reminds me of my New Triumph Tiger 100, there was a steel strap across the bottom of the tank and it supported the tank to the frame and it snapped. I obtained a new one and left it in the firegrate overnight and repainted it and had no further trouble. All i had done was normalise it. Looking at the old one showed crystalline fracture which I have found to be quite a common failure fault.
                                                #137818
                                                Jerry Wray
                                                  @jerrywray14030
                                                  Has Clive considered the conditions under which much of this technology was gathered? WWII had just ended, the Allies scoured the defeated Axis caches of documents to garner as much information as they could. You will be aware that the '4 Powers' kept their finds to themselves.
                                                  The searchers worked in closely guarded secrecy, always with the fear of the Soviets who could have taken possession of everything found in Eastern Germany, which at that time included Berlin.
                                                  I have been privileged to have seen some of the material gathered in its original form in my area of experience, before it was publicly available. Although the general direction of development was similar to that of the Allies some of the detail was novel and found later to be of value to us.
                                                  We should not run away with the thought that that Britain and America were far ahead at that time, After all the Germans might have developed 'the Bomb' first had it not been for the destruction of the heavy water plant in Norway.
                                                  JerryNotts
                                                  #146379
                                                  robjon44
                                                    @robjon44
                                                    Muzzer, I conducted the very same experiment during my schooldays near 60 years ago, a couple of miles from home was limestone pit (marl pit) being used for landfill. We visited regularly as there was no telling what might turn up that could be incorporated into one of our "projects" & also prime rat shooting territory. Same story, brand new 50 gallon drum, stand upright, add water, tighten plug, big bonfire, retire to discreet distance behind very large rocky boulders, Albert himself is credited with saying " If i knew what I was doing, I wouldnt call it research". Ends dome, collosal explosion, as steam condenses the drum is sucked completely flat from top to bottom, end exits edgeways & climbs vertically about 300 feet then levels of & glides about 400 yards across a ploughed field, impressive! We conducted a lot of our "chemical" experiments there, as there was plenty of cover (from shrapnel) & it truly was the middle of nowhere. To get back on thread, we did Woodwork & Metalwork in those days (yes, that long ago) as we had a whole country to rebuild, some of the small hand tools I made then, screwdriver blade, small adjustable spanner, depth gauge etc had parts that where hardened with Kasenit & have survived in my toolbox to this day still in use. Bob H
                                                  Home Forums Model Engineer. Topics
