Hello and welcome, by their shape, they look a bit like impact sockets, and also the lack of chrome or other plating might point that way. It may of course just be that they are old, before chrome plating was common on sockets.
The current Gedore's history goes some way back to germany, so I guess D1914 refers to an old Deutch standard; similar with 14SAE
7/16 will be the Across Flats (AF) size of the hex head it's designed to fit
No.D1914
14SAE
11mm Again will be the Across Flats (AF) size of the hex head it's designed to fit
1/4DIN probably UNF/UNC 1/4" thread diameter, but about 11mm spanner size.
Another socket is marked with:
29/32 Again will be the Across Flats (AF) size of the hex head it's designed to fit
No.D1929
1/2W This is Whitworth(& BSF), and refers to the thread diameter, but the hex head is about 23mm or 29/32" across the flats
23mm Again will be the Across Flats (AF) size of the hex head it's designed to fit. not a preferred metric thread size, but often included in sets, so it can be used on 1/2" BSW fasteners.
There's lots of tables on the net, but THIS RANDOMLY SELECTED ONE will provide a starting point
Bill
