Smart & Brown 1024 VSL Lathe
Home Forums General Questions Smart & Brown 1024 VSL Lathe
  • #744971
    David Leahy 1
      @davidleahy1
      Hi All,
      I have a Smart and Brown 1024 VSL tool room lathe, I am sure this is familiar to some of you? I have been running this successfully on a rotary converter for around 6 years and it has worked very well with no loss of power in any way. The rotary converter has now died and I am wanting to use a VFD in order to power the lathe. I have what I think is a suitable 11kw converter and wish to connect it up.
      The speed change on the lathe is operated from a console with an up and down button (40 to 2500 rpm from a 3-phase, 3 hp (2.25 Kw) motor) however when I connect the VRF it will be direct to the motor. Will by passing these buttons on the console still enable me to get the full speed selection from the VFD speed control? In pressing the up and down buttons on the lathe I assume its just control of electronic power to the motor rather then any form of gearing.
      Any advice would be greatly appreciated as I am not experienced in this aspect of motor control.
      Thanks in advance.
      Dave.
      Clive Foster
        @clivefoster55965
        The 1024 VSL variable speed is mechanical via a belt running on a pair of expanding contracting pulleys. The up – down speed control buttons control a second motor that drives the expanding and contracting pulley mechanism.
        You could set the pulley to somewhere near the middle by turning the control motor by hand, connect the VFD directly to the motor and use its controls to vary the speed. Which will be rather unsatisfactory due to the reduced power when the motor is running slowly. There will also be difficulties in switching the motor to delta connection to use the output of an ordinary single phase input VFD. If nothing else the connections aren’t accessible in situ and look a right pig to get out.
        The control system will need some re-jigging too. Not something for an electrical neophyte to get involved with. I briefly considered a stand alone VFD for mine. Took one look at what was involved, said stuff that and bought the Drives Direct set-up mentioned below. I do have the knowledge and skills to have done proper job but frankly teh work wasn’t worth the gain.
        Best option is to give it 440 V 50 Hz and use the standard system.
        But the only easy way to do this off a VFD is with something like a Drives Direct “whole shop plug and play system” which, within its its limitations, can be treated as though it provided proper utility 3 phase power. I’ve been running my workshop off one for many years.
        Frankly if you just have the one machine needing 440 v three phase power fixing the rotary converter is probably the simplest option.
        #745263
        Pete Rimmer
          @peterimmer30576
          If you really had to you could convert the 3 phase motor operating the speed control to 2-direction single phase by putting a capacitor across two phases then applying single phase power to either end of the capacitor (and the third point) for up and down speed.
          #745290
          Nealeb
            @nealeb
            I also have a 1024VSL and, like most of us, just a single phase domestic supply. In no particular order, these were my thoughts/actions (and possibly specific to my machine – S&B do not seem to have been entirely consistent about the electrics in these machines):
            Forget the star-to-delta motor conversion – the motor does not appear to be suitable for this. So I needed a 415V 3-phase supply.
            There is an electro-magnetic brake seemingly hard-wired to the motor which only releases when the motor is under power.
            A VFD hard-wired to the motor means that there is no supply to the control electrics without the motor “live”, so start/stop buttons will not function. My machine uses 110V “control” power for contactors, etc. Normally, this is provided by a transformer in the control box fed by the incoming 415V.
            What I did was to use a 240V to 415V VFD. Actually, this was a bit of an electrical fudge built by a company that no longer exists and consists of a good quality ABB 415V single-phase in/three-phase out with a voltage doubler circuit on the input. The best thing I can say about this is that it mostly works – see below. As an aside, I am grateful to Clive who has posted above; this “VFD” was one of the things that his much better solution replaced and he kindly passed on to me. There are now better-looking solutions that do the same thing relatively cheaply from companies like Ecogoo. The VFD connects directly to the motor.
            I wanted to keep the existing variable-pulley system and run the VFD at 50Hz output. I disconnected the internal transformer and fed the control box from an external 110V site transformer. Note that you need to remove the internal centre-tap earth in the site transformer. Note also that the speed-change motor, along with the oil pump and suds pump, are also three-phase.
            Fortunately, I found that the main fwd/rev contactors had a spare contact (N/O) available. I used these to connect to the fwd/rev inputs on the VFD. I now had a system that would start/stop the main motor controlled by the existing buttons. I left the motor-to-control box connections in place. Note, when one of the motor contactors operates, the VFD is also feeding (in a sense) in the opposite direction to the internal three-phase bus, which is also used to feed the speed-change motor, etc. The clever bit about this is that although I reverse the main motor via the VFD, when the phase-swap happens (which is how a three-phase motor is reversed) the corresponding original contactor also switches that feed back into the control box with a similar phase-swap. The overall effect is that the speed change motor is always fed correctly and up/down speed change works consistently whichever way the motor is running. This takes a bit of thinking about, but it does work!
            I could not see much use for the run/inch switch so I repurposed it. It now switches another VFD input which sets the output frequency to 25Hz for half-speed operation. I use this sometimes for thread-cutting. It can be switched on the fly while the motor is running.
            I have set a ramp-up time for the VFD output which brings up both frequency and voltage during motor spin-up. I was concerned that the motor brake might not release early enough during the ramp-up but in practice this does not seem to be a problem.
            And it all works! However, there is just one gotcha. The voltage doubler on the VFD input side feeds the VFD with what is, in effect, 25Hz. This is fine most of the time, but the machine load above about 2K rpm is such that the voltage doubler can’t cope and the VFD trips out with an input phase error. It’s OK when you test it with the spindle in neutral but the supply can’t cope with the bearing drag, etc, at the top end of the speed range. I keep thinking about replacing the VFD setup with one of the Chinese 240-in/415 out boxes (which are not a silly price and have had a good write-up elsewhere) but have not got round to it.
            By the way, you really, really, need to know what you are doing when you take the covers off the control box. There is a lot of high-voltage “stuff” going on in there!
            Having said all that, Clive’s solution is technically the better one!
