Smart and Brown Sabel
Home Forums Work In Progress and completed items Smart and Brown Sabel
Viewing 14 posts - 51 through 64 (of 64 total)
  • #483784
    old mart
      @oldmart
      I think you should ditch the milling attachment, you have a proper mill sitting next to the lathe.
      Jim Beagley
        @jimbeagley46363
        Posted by old mart on 03/07/2020 22:00:53:
        Haha. Good spot. I got the vertical slide before the mill. I’ll keep it for now
        #533123
        Alan Hands
          @alanhands91715
          Hi everyone really interested in this thtead as i have just bought this model !! quick question , what threads are used in the construction of the lathe , i want to clean out all the screw holes but do not have any imperial taps and dies yet, I assume the smaller threads are BA ?
          Alan
          #533129
          Martin Connelly
            @martinconnelly55370
            I would expect 55° Whitworth threads for the majority. At a push 60° UNC may fit in worn holes where the diameter and TPI is the same. I don't know about anything smaller.
            Martin C
            #533205
            Alan Hands
              @alanhands91715
              Thanks for the info !! now i have a place to start
              #533267
              old mart
                @oldmart
                The model A has BSF threads rather than Whitworth and also BA in the smaller sizes. The spindle threads are 55 degrees.
                #533274
                Alan Hands
                  @alanhands91715
                  i have the sabel exactly the same as jim's, so is that classed as the model A.
                  sorry for the dumb questions
                  #533275
                  old mart
                    @oldmart
                    No the model A is a bigger machine than the Sabel. Look at the "lathes UK" website.
                    http://www.lathes.co.uk/smartbrown/index.html
                    Edited By old mart on 11/03/2021 17:41:26
                    #533276
                    Brian Wood
                      @brianwood45127
                      Alan Hands
                      Not a dumb question at all, the Model A was a different machine altogether, but it was made by Smart and Brown
                      Regards Brian
                      #533286
                      Clive Foster
                        @clivefoster55965
                        As the Sabel is basically an improved, better built clone of the SouthBend 9" its easy to get a bit muddled up with model designations.
                        South Bends came in three versions model A with threading gearbox and power feeds, model B with power feeds change wheels for threading and model C with only plain hand feed and change wheels. Boxford were also clones and used the same model A-B-C identification system.
                        The Smart & Brown equivalents are SABEL with threading gearbox and power feeds, SAB with power feeds and change wheels for threading and S with only plain hand feed and change wheels.
                        So its an easy, and understandable, mistake to think Sable model A rather than the correct SABEL.
                        Which matters only because, as Old Mart says the Smart & Brown model A is very different being a true toolroom lathe and a much heftier beast. Although of similar capacity.
                        #533291
                        Alan Hands
                          @alanhands91715
                          Thanks for all the info, very interesting. so back to my original query threads are bsw ???
                          #533293
                          old mart
                            @oldmart
                            You will have to unscrew something to find out whether the threads are bsw or bsf.
                            #533298
                            Jim Beagley
                              @jimbeagley46363
                              There’s a right mix on the machine Adam as a single thread form doesn’t fit all requirements.
                              I know there’s a lot of BSW, and as Old Mart says there’s also some BSF.
                              I wouldn’t be surprised to find some BSC in there as well.
                              The only simple way of knowing is to try and tap or a known bolt or to measure the bolt.
                              Do you possess a thread gauge to get some TPI measurements?
                              The OD of the bolt is hopefully going to be very near the major diameter.
                              jim.
                              Edited By Jim Beagley on 11/03/2021 20:22:27
                              #562277
                              Ebenezer Good
                                @ebenezergood76202
                                That's a lovely looking lathe! my old Sable is resplendent in shoddy old silver hammerite maybe one day I'll treat it to a spruce up.
