Smaller diameter trapezoidal screws
Home Forums Materials Smaller diameter trapezoidal screws
Viewing 15 posts - 1 through 15 (of 15 total)
  • #273532
    Rainbows
      @rainbows
      Anyone know of a source of 6mm trapezoidal screws?
      8mm is sorta rare. 10mm and above abundant. Ready to use M6 thread but would prefer Tr6x1. Trying to thread 6mm bar over 140mm isn't something I would look forward to but I might try it anyway
      Rainbows
        @rainbows
        #273534
        Hopper
          @hopper
          If you go to Aliexpress.com and search "ball screws" they have some — at $120+ each! Might be worth making your own or using regular 6mm allthread bar!
          You may struggle to find a cheaper supplier than Ali-express, they are usually pretty good on price.
          Edited By Hopper on 24/12/2016 04:35:11
          #273543
            speelwerk
              @speelwerk
              Perhaps this one, Niko
              not done it yet
                @notdoneityet
                A cinch, especially if you look, how it can be accomplished, on u-toob. Try myford boy.
                #273568
                mark smith 20
                  @marksmith20
                  Hard to find anything under 8mm, i was looking the other day as i have a problem with the screws on my proxxon mf70 micro mill which i believe uses 6mm screws . I dont want to use expensive ball screws as i use manual feed.
                  Every day threaded rod sounds rather `un-precision` and usually isnt very straight.
                  #273580
                  Circlip
                    @circlip
                    If you're looking for screws, try Screwfix, they have most sizes including "Twinfast"
                    Regards Ian.
                    #273603
                    Circlip
                      @circlip
                      Perhaps if the O/P inputted the CORRECT terminology for the item they were searching, Goggle, Yaboo or Beeeg may give the required answer.
                      . . .. . . . . . and YES Michael, I've used the rite wurds.
                      Linking Trapezoidal and Lead screw seems to wurk.
                      Regards Ian.
                      Edited By Circlip on 24/12/2016 16:58:25
                      #273612
                        Interesting choice of link, Ian …
                        [quote]
                        • Thread milling up to 9 ¾”dia x 16 ft long and 3.5”dia x 25 ft long
                        • Thread whirled up to 6 ¼” dia x 39 ft long
                        [/quote]
                        I accept, of course, that the stated "up to" dimensions may encompass 6mm dia x 140mm long, but they would not have been my first choice of potential supplier for Rainbows' requirement.
                        [posted in good humour]
                        #273633
                        peak4
                          @peak4
                          Would something LIKE THIS do the job?
                          or maybe contact Kingston
                          Edited By peak4 on 24/12/2016 21:04:32
                          #273716
                          Rainbows
                            @rainbows
                            Might try making it myself first so I feel less bad if I resort to buying it. Thanks for all the links though. Got them saved to contact later.
                            #274890
                            Howard Lewis
                              @howardlewis46836
                              When I first saw the heading, I thought of Trapezoidal as in section of the parent metal, similar to Tri Lobular screws. Then the references to leadscrews made me think that maybe the trapezoidal referred to the thread form, similar to ACME.
                              Put me out of my misery; which is it?
                              #274893
                                It is the metric form of ACME which uses 30degrees rather than 29degrees.
                                J
                                #274894
                                Rainbows
                                  @rainbows
                                  Trapezoidal in terms of thread form, the metric equivalent of ACME. After seeing the term lead /screw/ so much I started mixing up terminology.
                                Home Forums Materials Topics
