Hello.
My apologies for re-awakening a dormant thread, but I have read this thread, and others, and I am still none the wiser.
As I understand it, most of mainland Europe, and the US as well, use steel for boilers. I also believe that the vast majority of pressure vessels made at 1:1 scale, including boilers far in excess of any specification we have for at model scale, are also steel or stainless.
So I’m not sure what is special about model steam in the UK where we insist on Copper?
Some arguments have been put forward in this thread that I’m not sure are correct, such as time to raise steam – back of the envelope calculations suggest ….. to me at least…. that the time difference will be minimal.
Some line up better, such as wastage allowances, but I don’t see why that can’t be built in – the process is well known and calculations are available.If a design calls for 3mm copper, I wouldn’t object to using 4mm or 5mm steel instead. It’ll likely work out cheaper in materials.
If I can fit the boiler into scale, and it’s safe, I don’t really understand the problem.With Stainless, I don’t believe that the issue is as significant as is being made out. Stainless is used, and has been used for years, by the flash steam world at vastly higher temps ( 700 degrees + ) and pressures ( 2000psi + ) for seasons on end with no sign of any issues despite regular testing.
The welding can be trickier, but the world HAS moved on from the times of LBSC, no matter if sometimes I wish it hadn’t. Welding technology has moved on hugely, and there are a lot more competent Stainless welders these days, I think partly because the systems that have make high quality stainless welds easier to make. Parts that would have previously been made from formed sheet can now be CNC’d out of solid. In all, there are a lot more options available.
For myself personally, producing a steel boiler would be a lot cheaper, and likely as easy, if not easier, than producing a copper boiler, especially at large sizes. Stainless would add to the time and cost, but again from a purely personal point of view, I believe I can still produce/have produced, a stainless boiler at the same cost as copper which will be many times more resilient in every way to a copper boiler.
There is a separate case of the Insurance companies, but I believe that if the welds are signed off and the pressure tests passed, Insurance will be given.
So I get to the point where, if I was undertaking building a largish boiler which would work quite hard, and I had to choose between a copper/silver solder boiler and a stainless boiler, or even just an alloy steel boiler, then I personally would feel far more comfortable with a steel boiler.
Given that, and given that most of the rest of the world uses steel, I *STILL* don’t understand the resistance to it? It almost feels like us UK model engineers are looking for reasons, any reasons, not to make a move to it.
Please don’t take this thread as a rant, it’s not. It’s just me being confused, and looking to understand the situation better.
Edited By Alf Jones on 31/10/2011 10:43:26
