My brother and I regularly run a 5″ gauge loco based on an American Forney. This has a steel boiler and it steams like a witch. It takes no longer to ‘brew up’ than any equivalent sized copper boiler. As mentioned before, the conductivity of the boiler material makes little, if any, difference. I’ve also noticed that the boiler pressure is very stable, unlike some copper boilers, possibly due to the greater mass of hot metal in the steel boiler.
The loco was bought from a workshop clearance for a song purely because it had a steel boiler. It had stood for at least 20 years, had no paperwork, and so had to be considered possible scrap. We removed the boiler and took it to the club for an inspection and a test which it passed with no problem at all. All the steel is 6mm thick and all the welding looks of a professional standard. The thing weighs a ton! One of our inspectors tests gas tanks for a living and happens to have an ultrasonic tester which showed no sign of thinning of the steel. The only problem was a very slight weep from one of the copper tubes which was cured with Loctite.
Funny enough, also in the same workshop clearance was a steel boiler for a Sweet Pea. That looked professionally made and never been used.
I think for a 5″ gauge wide firebox loco, steel is a definite alternative to copper. Probably not for a narrow firebox job though where the thickness of the steel will affect the grate area adversely.
With regard to dezincification – I’ve found a few cases on fittings when working on older loco boilers. One steam valve snapped clean off with little effort when I tried to remove it from the turret. A similar thing occurred with a brass blowdown valve. I always use bronze or gunmetal for any fitting that screws into a boiler. Brass should be fine for anything outside the boiler.
