Small Nylon Gears
Small Nylon Gears
Home Forums General Questions Small Nylon Gears
  • #22094
    Chuffer
      @chuffer
      Chuffer
        @chuffer
        I have been trying to locate a replacement gear for the Hip Shaking Santa (yes I know it's sad!) Christmas toy which we have. It no longer works as the gear has cracked at the bottom of one of the teeth, consequently it jams up the gear mechanism. It's a plain gear 6mm o/d, 5mm wide, 10 teeth and it fits on a 2 mm shaft. I've looked at both Davall and Muffetts websites and also done a google search to no avail. Looks as if it might be a bin job unless one of the forum members knows where I can get one. I'll bet there are millions of them in China all lined up in gearboxes for the Christmas toys we will buy this year…….??
        Regards.
        Nigel
        #90577
        Ian P
          @ianp
          Nigel
          Have you looked in the HPC catalogue? or on hpcgears.com
          In my experience they have the biggest range and most of it is in stock. Prices are good but a helluva lot more then they used to be and postage is expensive. They justify it on the 'we dont have a minimum charge' basis.
          If nothing else its worth getting the paper catalogue before they go web based only.
          Ian
          #90578
          Chuffer
            @chuffer
            Ian
            Many thanks for the lead. I've had a look at the HPC website and downloaded their catalogue (all 837 pages of it!). I've also sent a request for one to be sent to me as the range of gears is, as you say, very extensive and it will be easier to thumb through a catalogue rather than staring at a screen.
            From the quick look I had in the spur gears section nothing seemed to jump out as being what I need so if any other forum members have a suggestion then the more likely I am to find a suitable gear.
            Nigel
            #90579
            Ian P
              @ianp
              Really its the PCD you need rather than the OD but there is are 10 tooth gears at 5.2 and 6.5 OD in the metric section and similar diameter ones in imperial (see G0.5-10 for example).
              Depending on how much trouble you want to go to you could file one by hand, I doubt its has to run at high speed or high load, clock and watchmakers made things like that years ago.
              #90582
              Steve F
                @stevef
                Hi
                Squires Models in Bognor Regis sell some plastic gears. I am not sure if it matches your requirements exactly but might help. They do a large catalogue of bits and pieces. Many items are not very common these days.
                Their website is **LINK** look in the tools amd materials catalogue page 390.
                regards
                Steve
                 I have no idea why the link doesnt work.. go here http://www.squirestools.com/
                Edited By Steve F on 10/05/2012 23:46:21
                #90593
                MichaelR
                  @michaelr
                  Hi Steve
                  Good site some handy stuff hope this link will work. Squirestools
                  #90595
                  Packmule
                    @packmule
                    Hi Nigel,
                    If you dont mind the work in Maplins they have a product called Poylmorph.Its small plastic /nylon beads. You put some in hot water and it becomes mouldable to any shape and can be machined. It goes clear when ready and white when cured. Any surplus can be reheated and used again. I think its about £9-10 a tub but brilliant stuff.
                    #90598
                    Keith Long
                      @keithlong89920
                      Hi Nigel
                      Also worth looking at Rapid Electronics and Technobots. It might also be worth popping into your local model shop that does radio controlled cars planes etc. as most of the servo manufacturers sell sets of replacement gears in both plastic and metal. You might well find someting that you can adapt.
                      Keith
                      (no connection with either co. above except as a happy customer who's bought small gears from both)
                      just looked at Technobots and  it looks as though they've got what you want at about 20p each
                      Edited By Keith Long on 11/05/2012 10:09:15
                      Edited By Keith Long on 11/05/2012 10:37:08
                      #90602
                      Chuffer
                        @chuffer
                        Many, many thanks to all who have responded to my posting. It never ceases to amaze me the information and advice which is available on this forum and is so freely given.
                        I've had a look at the Technobots website and ordered 10 pinion gears (some for stock!!) – total £1.50. The killer is the p&p which brings the order up to £4.75. Still, if it sorts out the problem it will be worth it and we can have our Hip Shaking Santa back in action for next Christmas!! Still sad isn't it??
                        Regards.
                        Nigel
                        #90604
                        Chuffer
                          @chuffer
                          A couple of things I forgot to mention was that I had a look at the Squires website – really good with lots to spend your hard earned cash on, but they didn't have any gears listed which would be suitable. I also had a look at the Maplin website and in particular the Polymorph granules which could be a useful thing to remember for the future.
                          Regards.
                          Nigel
