Small MT2 Tailstock Chuck for ML7
Home Forums Workshop Tools and Tooling Small MT2 Tailstock Chuck for ML7
Viewing 3 posts - 26 through 28 (of 28 total)
  • #582789
      I'd put the hole into the faced off bar not try and drill the apex. Turn the taper after drilling.
      Dr_GMJN
        @dr_gmjn
        Posted by JasonB on 28/01/2022 12:28:32:
        Yes, I was just describing the end result rather than proposing trying to drill at an apex.
        #582799
          Posted by Dr_GMJN on 28/01/2022 10:21:32:
          Posted by Michael Gilligan on 28/01/2022 09:37:18:
          Posted by Dr_GMJN on 28/01/2022 08:25:44:
          Posted by JasonB on 28/01/2022 07:19:19:
          Has the Myford got a through hole […]
          Yes, the tailstock MT2 taper is hollow if that’s what you mean? […]
          Hence my [presumably inappropriate] suggestion, yesterday.
          Sorry Michael, I thought you suggested a method of using a hollow MT2 taper and making some kind of sliding arrangement, or the tailstock mechanism you linked to. You didn't mention a collet?
          Jason I think was suggesting a simple tailstock collet to hold the ARC supplied sensitive chuck – thus reducing overhang and weight of having a second chuck to hold the first?
          Unless I've misunderstood, these are two completely different concepts in terms of cost and complexity?
          Just to be clear … What I was suggesting [and the reason behind my using those selective quotations] was to bore a MT blank to accept a free-sliding shaft which accepts watchmaker’s collets. The mechanism shown in the Bergeon example is, to my mind, ‘optional’ … at small diameters, pushing with a fingertip should suffice, and is the most ‘sensitive’ feed mechanism available.
