Arc sell a range of MT2 tapers with various tapers on the nose – and the chucks to match them.
I also purchased a 'sensitive' drill but frankly felt that the drill shaft was far too loose in it's body – so I remade it as mentioned a week or so back. However, I think it's worth pointing out that you don't really need this kind of drill holder (with knurled bearing) as when used in the tailstock, it doesn't need to revolve.
You could use any small chuck and just make a sliding shaft into an MT2 blank arbor.
The knurled bearing is required if you use it in a drill or mill – as then the body does spin. This 'sensitive' type of chuck & holder is also useful if you have a small horzontal mill with a vertical head that has no 'quill' (so drilling has to be done by raising/lowering the table). My re-built version has a reduced 10mm shaft end, so it can fit in an ER16 collet and be used on my Taig milling head.
IanT
Edited By IanT on 27/01/2022 17:56:28
