Frank,
Because I broke mine a few weeks after purchase, I obtained (under warranty) replacement plastic gears from Warco, however at about the same time there were a number of articles in MEW about improvements to the X1 lathe, and other equipment, As a result, I decided to incorporate some of these into the MiniMill at the same time.
My problem is that a) it is a hobby, and thus doesn’t rate overhighly in the general scale of things; and b) I get involved in doing other things, both hobby type, and for the house & grandchildren, hence I haven’t yet finished the repair/overhaul.
It may be of interest to note that like other people, I have found casting residue where it shouldn’t be!
As to the actual gears, this does involve a major dismantling to get at them, eg (from memory) remove motor & controller, remove spring return, remove top stop, lift head upwards and off the slide, remove slow and fast vertical feed mechanism, remove speed change lever, remove rear of head (it’s in two parts), remove intermediate shaft (requires knocking out of bearings, and finally remove main shaft/spindle (also requires knocking out of bearings).
Then replace and rebuild in reverse order.
The Arc Euro Trade metal gear set does appear to be a direct replacement. I haven’t tried them for a fit, but they measure exactly the same as the original plastic gears and so I have no reason to believe they will not work. I have to say that I only found out about these after I had obtained and fitted the replacement plastic gears, so they are now in stock just in case. I’m loth to replace until forced into it because of the difficulty in knocking out and replacing the bearings.
Yes it is true that there are belt drive conversions available for the X2, and by all accounts they are quieter as well, however, until I see that someone has successfully converted a MiniMill, I will leave well alone, the reason being that although the MiniMill does appear to be based on the X2, there may well be, in fact definitely are, slight differences between the two mills, eg the spring return system for the vertical motion, and, I think, the location of the speed gear change handle. Furthermore, I have a general dislike of making changes which cannot be reversed in the event of unforeseen problems.
For what it’s worth, I do now think I may have made a mistake in buying this mill. One of my reasons was because of lifting limitations as a sole worker, however after I had bought the maxhine, there was an article in MEW where someone bought an X3 or similar, and dismantled it to get it into place – something that I never though of. I did want the biggest I could comfortably handle, and had the idea of dismantling to install occurred, then I may well have gone for a bigger machine. Having said that, I do not have any reason to criticise the MiniMill – I went into it with my eyes open, and it does seem to do what it is supposed to do.
Hope this helps, Frank.
Peter G. Shaw.
