I've done a Google search but only come up with one company offering small scale sections in brass and they're all metric. I'm after both angle and channel with a 3/16th dimension on all sides and a 1/32nd wall thickness. The model railway guys used to be spoiled for suppliers back in the day so if anyone knows of a company still in business, would you mind sharing? K&S (available almost everywhere and it's clones – Albion Metals) won't do as it's too thin and folded. It needs to be milled. Thanks.
I am fairly sure that Roger Melton at Just the Ticket, (01980 610058 or JustTheTicketEng@Gmail.com) will be able to assist you. His catalogue lists loads of milled imperial brass strip and sections, sold by the yard. Usual disclaimer applies.
Chris, would (if you can get it), 5 mm x .75 mm, It will be a few thou wide, a few swipes with a file on the flanges, and you'll be back to 3/16". Ian S C
Author
Please log in to reply to this topic. Registering is free and easy using the links on the menu at the top of this page.
