Hi Windy,
My first thoughts are “you poor s*d”
Second thoughts, are you making jets? If so, can you not counter-bore most of the hole and only drill the small hole through the last bit.
Drilling Stainless creates problems, you need constant pressure to prevent work hardening the surface, but small drills don’t like much pressure. Speed is critical, don’t think going faster think going slower, let the drill do its thing and cut, not high speed polishing. Going too slow though puts too much strain on the drill. As I said problems.
I have drilled 0.8mm holes on my Bantam with its top speed of only 800RPM , not the many thousands that the books recommend, taking things very carefully. SHARP drills and flute cleaning are vital, but I wonder how well you can hand sharpen such small ones.
Carbide drills are unlikely to be the answer, the smallest I could find in the J&L catalogue is 1mm, most makers start at 2mm. They are incredibly brittle and quite unforgiving of any “heavy handedness”
On the subject of small drill sharpening, you could not do better than make DAG Brown’s four facet drill sharpener, it works a treat and not too difficult to make. There is a bit of a write-up of a version at
http://www.gadgetbuilder.com/DrillSharp.html
“Thinks”, could our editor be persuaded to reprint the original articles in one of his “Best of ME” specials? I think it qualifies, as it is supposed to be one of the “most made” of all tools from the magazine.
I am sure someone will suggest a marvellous way of doing the job, but the only other alternative that springs to mind would be to use an EDM, that’s a “spark eroder” to you and me. Acquiring one of these would be impractical unless you are going to corner the market in small hole drilling, which begs the question , just how many of these holes are you contemplating drilling?
christephens
