Pretty much as per the description, I'm struggling to clear much needed space in my workshop, and these items have been sat idle for years waiting for me to "get around to" using or selling them properly.
The following items are available on a Pay What You Want basis, I'd like to get something back for them, but I'm not going to quibble because mostly I'd just like to see them with someone who is going to use and enjoy them.
Ideally collected from just south of Sheffield, but I can probably deliver for fuel money in/around the M1 and A1 corridor anywhere between Nottingham and York.
Small Lathe:
It's the tiny geared-head lathe which is listed as (and pictured in the article of) "Unknown Lathes No. 93" on Lathes.co.uk
I've run it a couple of times over the years and it's actually very good to use despite one chipped gear tooth.
Originally came from the son of the man who built it (from a casting kit apparently, with a number of accessories (3 jaw, 4 jaw, faceplate) and some provenance information (including photos of some Loco's he built with it) which I'll include with it.
I'm a bit conflicted about parting with it as it really is a lovely item, and I have had half a mind to mount it on a wooden plinth and display it on my mantel-piece over the years, but that seemed like a step too far.
So it deserves to be cared for/used by someone rather than sat on my racking in "preservation".
Horizontal Mill:
A "Pallas Horizontal Milling Machine Model C" (Lathes.co.uk link, you'll have to scroll a bit)
Bought from a print-works who had been using it with a grinding wheel and jig to true up the top of metal type.
It's been fully stripped and cleaned and repainted (apart from one casting which is primed but needs a top-coat); the short lived sojurn as a grinder does not appear to have done it any harm thankfully.
It's currently still disassembled, but all the parts are retained in trays including a choice of lever or screw-feed for both X and Y.
I did have a view to permanently setting it up for cutting gears, for which it would be an ideal machine, but just don't have the space to keep it really.
I'm not willing to offer it with the motor mount I bought it with as it was clearly dangerous, but fabricating something less finger-remove-y should be straightforward.
Hand/Flat-Belt Operated Pillar Drill:
Similar situation to the horizontal mill, has been disassembled, cleaned and primed for final painting but no space/time to re-assemble.
Has mechanical and hand down-feed by screw and two drilling speeds, as a drill it was an alright user that could maybe do with a new chuck/chuck jaws.
It strikes me that it would probably be a nice item for driving from a small steam/gas engine for demonstration purposes at rallies once painted.
Motors:
4 off single phase motors.
- 2 x 0.75 HP foot mounted,
- 1HP & 3 HP with lever operated clutch/break and anti-vibration mounts.
All running smoothly when last tested, but surplus to requirements.
Edited By Jelly on 21/03/2023 16:10:55
Edited By Jelly on 21/03/2023 16:11:55
