Posted by peak4 on 29/03/2023 13:09:08:
Posted by Dr_GMJN on 29/03/2023 12:21:14:
A Google search doesn't give any results for what I assume is the correct designation: SCGT 06(T)304.
Any ideas?
Thanks.
As with other folk above, I've had a good look around, including Chinese sites and failed to find SCGT060204 anywhere, so I guess either you need to move to a larger holder, which as you say defeats the object.
On the other hand, you could buy a replacement holder and go for the diamond shaped inserts at the smaller size, as CCGT060204 are readily available; I've just bought a box.
Last comment relates to your SCGT06T304 assumption above.
I'm not sure it's correct; the T3 part refers to the thickness
02=2.38mm
T3=2.78mm
03=3.18mm
T3=3.97mm
04=4.76mm
I'm not sure that XXXX06T304 would be common in any shape; I think all my 06 sized ones are 02 thickness.
Bill
Thanks Bill, yes that's why I put the "T" in brackets. Either way, there's nothing out there.
I do have the diamond shaped GT inserts, which I've put in my L/H, R/H and straight holders. They are my "go-to" tools for most materials these days. I just thought It would be nice to have a 45 degree chamfer tool in the same series though, since I already have the holder.
