Made this little bench grinder a few years back to mount on the bench. I already had a 6" and 4" but wanted a smaller unit for fine work. The grinder takes 762×25 mm belts. I chose this size because of belt grit availability 40 – 1000.
Originally it took two belts, but the motor didn't have enough power, so, I downgraded it to a single belt. If I ever come across a bigger, freebie motor, I'll add another belt.
The table is adjustable, it has tracking, wheels are Delrin and it has a diamond wheel on the end of the driven wheel for sharpening cutting bits for the lathe.
Doesn't get a lot of use, mostly the diamond wheel, but it comes in handy sometimes.
Edited By Tony Hoggo on 09/08/2023 06:44:14
