I've had the Axminster 8-inch slow speed grinder for a week. I bought it to accommodate the CBN wheel I bought from them only a few days prior to that. My reasons for buying a CBN wheel are set out here.
I can't presently recommend either this Axminster slow-speed grinder or their CBN wheel. I'm awaiting some replacement parts before I decide whether I'll keep either.
Problems are as follows: whilst I can get the supplied white stone wheel [the one out of the two stone wheels supplied that I want to use] to run so true that no lateral wobble is detectable by eye, the CBN wheel with its special CNC-made bushes has at least 0.5mm of lateral wobble that can't be rectified no matter how the bushes or the wheel are rotated before tightening the lock nut.
The shaft of the grinder is acceptably straight, with only 0.02mm of runout, so the problem is probably either the bushes or the wheel or the lock nut, or a combination of all three. Axminster are sending out replacement bushes to see if it cures the problem, but it's turning into a rather long wait for these to turn up.
I've tried placing cardboard washers between the small shoulder on the shaft and the inner bushing, as well as underneath the locknut, and this reduces runout by about two fifths, but it's still unacceptable runout in my view for a wheel that I bought specifically to be able to use the side for grinding drills on.
You would think it would be the other way round with the wheels – that the stone wheel with its crudely cast bushings/washers would be the one that was difficult to cure of wobble, and the precision turned CBN wheel with its CNC-made bushings would be dead straight, but sadly that's not the way things presently are.
ETA: I forgot to say that with both wheels installed the grinder vibrates horribly when powered up. If only one wheel is installed [doesn't make any difference whether this is the stone wheel or the CBN wheel] the vibration reduces considerably.
Edited By Bill Phinn on 05/12/2022 14:30:54
