Dougie,
What Neil has said all runs true, what might be you main concern is building the engine in the first place.
You really need to find someone who has built one of these engines, because some of the E.T. designs are so far out on plan dimensions and casting qualities they usually end up under the bench.
The last one I built was the ‘Whippet’ (and mine does run), using the old Woking castings. If you followed plan dimensions and casting markings you would end up with head bolts going into the cylinder, and that is just one example, there were many more plan errors. I had to get an ali welding friend to build the castings up in strategic places.
Hemingway, who took over the range from Woking ‘redid’ the castings for it, the Modelenginenews chappies attempted to build a couple, and it seems to have died a death. Search for Whippet on this page.
The Seal is another very good example, the castings were redone by Hemingway, and they are very different from the original casting shapes, but no effort was made to put right all the outstanding mistakes on the plans,, things like exhaust manifold studs cutting through head hold down bolts etc.
So as I said, find someone who has previous knowledge of using the plans and castings of this engine, only then, after it is proved to you to be fairly easily built, start to think about getting it to run like you want it to.
Bogs
