Slot Machines: How does a mechanical one arm bandit mechanism work?
Home Forums The Tea Room Slot Machines: How does a mechanical one arm bandit mechanism work?
  • #629225
    Robert Atkinson 2
      @robertatkinson2
      Posted by Martin Kyte on 13/01/2023 20:05:08:
      If you make a quarter scale machine that takes quarter scale coins how is that gambling?
      regards Martin
      Does not matter if it has a slot or not of if it takes tokens or leegal tender. it is still a gambling machine.
      Robert Atkinson 2
        @robertatkinson2
        There were responses while I was typing and doing other things.
        The gambling act covers a wide range of activities and offences.
        The "no prize" 248 says it only applies to sectons 37 and 242
        37 is use of premises and 242 is making machine available for use.
        There is a contradiction in 243 (manufacture supply etc) says there no offence if an exception under 248 applies which sounds like an out, but there is no exception for 243 in 248.
        From their website the Gambling Commision clearly thinks you need a licence or permit as a private individual to cover section 248.
        The only way to be sure is for a case to go to court.
        As I said before, A single machine permit is only £40 so why take the risk? Get one and you are covered.
        B.T.W I don't agree with gambling generally, Haven't been in the industry for 40 years and don't even play video games.
        Robert G8RPI.
        #629236
        Roger Hart
          @rogerhart88496
          Way way back a local publican got me to oil and meddle with these things. Nasty horrible things to work on.
          I do remember the mechanical ones had some little screw-in clamps that blocked particular wheels from settling. So the machine could be fixed not to pay out much. The general strategy was to make the machine generous on say a Thursday night and stingy on Friday etc etc. The electric machines had a rotary switch to do the same job. A lesson in life.
          #629240
          Circlip
            @circlip
            I remember a 'Committee' man in a WMC rushing to switch off an electric bandit that decided to vomit far in excess of the Jackpot. Caused a bit of a shindig when challenged.
            Regards Ian.
            #638730
            lachie wilson
              @lachiewilson30526
              hey just wondering if anyone may have some knowledge on an issue i'm having with my bandit. when the pins that drop into the rotating disks that trigger pay outs are engaged my second and third reel struggle to spin and often barely make a single rotation but when i unbolt the pin mechanism so they don't drop into the disks everything spins perfect.
