Good evening,
I will use the drilling technique between two pieces of bar as the accuracy of a reamer is not required.
The aluminium should be here next week.
I have been making some clock parts that are over 100mm long recently. The Unimat SL has a long travel leadscrew with a thread pitch of 1.0mm. This makes these operations a little tedious.
I've put together the required equipment to fit a stepper motor to the long travel. This will run in either direction using push buttons and be speed controlled, independent of lathe speed.
Part of this equipment is a third party motor mounting bracket that wasn't all it should have been when it arrived. The section that fits underneath the bed bars of the lathe and holds the motor is fine, the clamping piece that holds this to the bed bars is not. It is this piece I will be remaking.
80mm long by 20x30mm section with two 12mm slots in it to fit snugly over the bars. Two M6 bolt holes to complete.
kindest regards,
David
