On
2 August 2024 at 15:05 Bo’sun Said:
… I have a 2mm x 100mm x 130T slitting saw, purchased from an established supplier.
How much peripheral runout is considered acceptable?
I’ve checked it using a dial indicator with an “elephants foot” stylus and measured 0.55mm (TIR) runout.
I welcome comments on my method of measurement. I wasn’t sure how else to do it.
Accurate measurement is vital in manufacturing, and they go to considerable trouble to get it right. Not, repeat not, simple and very easy to get wrong, especially when amateurs have a go! Two major problems:
- Poor technique and equipment.
- Misunderstanding the results.
Accurate measurement is far less useful in a hobby workshop because we fit parts together by comparing one against the other rather than making them accurately and precisely within toleranced dimensions.
As inexperienced measuring is a rich source of confusion, I recommend keeping it in reserve.
Bosuns first test should be: “does this slitting blade cut metal satisfactorily? (Even if some teeth go clunk-clunk.)”
This is a real-world test that doesn’t rely on making an accurate measurement or understanding what the measurement means in practice. After confirming that the arbour and saw are installed properly a blade that doesn’t cut can be sent back without further ado.
If the blade doesn’t cut properly, then careful measurement will eventually identify the cause. But I recommend this as a second stage only used if absolutely necessary, with the operator wide-awake to the possibility he’s doing it wrong!
I don’t know why, but slitting saws are often imperfect. I suspect it’s because some teeth are ground slightly over-size, rather than the mounting hole being off-centre. Hard to prove without a lot of very careful measuring. If the cause is a few slightly protruding teeth, may not matter much. Although they do more work than the others, all the teeth get a chance to cut as the saw is pushed into the job. I see slitting saws as good for making slow precision cuts, not for quick hacking.
RPM and feed-rate are important too, and there’s a relationship between the number of teeth, the material, and the feed-rate. Anyone got any advice on choosing the number of teeth needed?
