Whatever you use, DO NOT use a key to the arbor.
If it jams, then you will definitely need a new saw! And if it shatters, the debris might hit you.
Mostly, I use a 1/16 saw for this sort of work.
Keep the feed slow; work on the basis of 0.001"/tooth.
Good Luck!
