Slightly large lathe
Home Forums Beginners questions Slightly large lathe
  • #577755
    Peter Simpson 3
      @petersimpson3
      In my workshop I have a Myford S7 and a Boxford ME10. As they are very similar in size, I'm considering going for a slightly larger lathe. One of the more modern Boxford STS gearhead lathes looks a good size option. Had anybody got experience with STS range or suggest a suitable replacement for the ME10
      Peter Simpson 3
        @petersimpson3
        #577772
        John C
          @johnc47954
          Hi Peter,
          I have a Boxford STS 10-20 (often generically listed as X-10) with metric dials and can highly recommend it. It will cut metric and inch threads with use of a set of changewheels – these seem to go missing but are available. Changing the changewheels is very straightforward. The D1-3 chuck locking system is very practical, makes changing chucks a breeze and allows the use of operations in reverse. There is a bush that goes into the spindle to convert to MT3 if you want to use collets or tooling in the bore. Top speed of just over 1000 rpm is no limitation to me, and if you keep your other lathe that will give you the higher speeds. Tony Griffiths' site 'Lathes.co.uk' does a very good write-up on the STS variants – listed under Late Model Geared Head Boxfords,
          Gavlar
            @gavlar
            I currently have an Boxford ME10 and a Boxford 280. in my workshop.
            The X10 range outclasses the 3565 range by a country mile.
            The X10 range is not much larger physically but has a bigger spindle bore, a bigger motor, greater swing, has a gear head and apart from the training lathes, an excellent gearbox. They have 6 or 9 (and possibly 12?) speeds depending on model. Mine was missing the changegears but a full delrin set can be had from ebay for about £60. They all come with 100/127 compound gear as standard. D1-3 spindle nose is (IMHO) far better than threaded. Whilst some sellers seem to hold out for silly money, they can be had for less than the cost of a decent AUD. There is currently one on ebay, well equiped with 3 and 4 jaw chucks, what appears to be a full set of changes gears and QCTP that has just been relisted as it didn't sell for the £2000 asking price.
            One thing to beware of, the X10 range was never as popular as the 3565 range so whilst they are pretty bomb proof, if you do manage to break something you will struggle to buy replacement parts. If you need steadies, buy one that already has them, you will be very lucky to find any for sale and the few I have seen sellers ask silly money.
            #577982
            Richard Millington
              @richardmillington63972
              I have a Boxford 280 (9 speed), a vast improvement on the BUD which was before it and with virtually no more space taken (just a little deeper).
              Mine came with everything except steadies, I have already made a fixed steady and travelling is on the projects list.
              If you get the original QCTP extra holders can be expensive, RDG ones can be made to fit with a little grinding to the slot.
              #577989
              Peter Simpson 3
                @petersimpson3
                Are these gearhead versions much heavier than an ME 10. As my workshop is in my garden so my lathes and milling machines all needed to be stripped down to move the "lumps" from the drive to the workshop.
                #578000
                Gavlar
                  @gavlar
                  According to the X10 manual, they weigh between 365 and 385 kg, dependent on bed length. I'm not sure of the weight of the ME10, I seem to remember that on the proper base they are approaching 300 kg, but don't quote me. The X10 is not a lot more difficult to strip for transport than the earlier models.
                  Edited By Gavlar on 01/01/2022 23:31:54
                  #578019
                  clogs
                    @clogs
                    I have a Super 7 with a thread cutting g/box plus a really sweet Colchester student Square head……
                    very happy with both….
                    Dont get to hooked up on who's bigger lathe u get….more important to find one thats not a junker….
