John, you are correct – the exhaust port in the cylinder under the slide valve is larger than the inlet, which is another reason to expect the exhaust from this port (in the cylinder casting) also to be larger than the inlet (to the valve chest)
60019, Interesting point regarding drain cocks, but the cylinder does have positions for the normal tapered plug type drain.
mgj, the feed into the valve chest is 9/32 and the exhaust from a 1/4 inch hole drilled in the cylinder casting which connects the larger port face in the valve chest.
I can understand using the increased capacity of a larger feed pipe so more steam is available upon demand.
My this can get confusing! but to recap – feeding the engine I have a larger inlet pipe than exhaust pipe, and on the cylinder valve face a larger exhaust port than inlet port!
