size of T50 staples
size of T50 staples
Home Forums General Questions size of T50 staples
  • #301392
    Douglas Johnston
      @douglasjohnston98463
      I have an old tacking stapler that I need some staples for but am not sure what size is needed. I have spent the last hour googling about staple sizes and have made some progress but can't find the detail I need about T50 size staples.
      The inside measurement between the legs of the required staples is exactly 10mm but I can't find if this is the T50 size or not. All the references I have found just give the length of the staple legs but not the space between them.
      ​ If anybody has some T50 staples handy can you please measure the inside dimension for the width of the staple.
      thanks,
      Doug
      Douglas Johnston
        #301395
        roy entwistle
          @royentwistle24699
          I get them to be 9.6mm. I get the part of the stapler that they sit on when loaded to be 9.00mm
          Roy
          #301398
            I've just measured a couple of "genuine" Arrow T50s and get 9.4 on one and 9.5 on the other, both 10.6 outside width
            #301399
            MW
              @mw27036
              You have to be careful with staples because some of them are brand specific, like the wickes metal one I own. Only takes it's staples.
              Michael W
              #301400
              Bazyle
                @bazyle
                older so you are probably looking for 3/8in
                #301403
                Douglas Johnston
                  Thanks for the replies, it looks like the T50 ones will not fit since the part they slide on is about 9.9mm wide and 3/8" would also be too narrow. It may well be some non standard size that I can't get now and will have to ditch the stapler.
                  Doug crying 2
