SIP 14″ Professional Bandsaw
Home Forums General Questions SIP 14″ Professional Bandsaw
  • #552072
    Malcolm Farrant
      @malcolmfarrant93389
      I have a SIP BNDSAW, where the switch went wrong. Sip have supplied a new switch, but seem unable to provide any Wiring deatails.
      Does anyone have a copy of the Wiring as I dare not connect the new switch, as I may cause more damage.
      It does seem extrodinary that SIP cannot privide this !!!..
      Any assistance would be a great help
      Thank you
      Malcolm Farrant
      Malcolm Farrant
        Wiring Diagram
        #552073
        Former Member
          @formermember12892
          #552076
          ega
            @ega
            Having been caught out many times before, I now try to remember to take notes and photos as I dismantle.
            Good luck!
            #552078
            Ady1
              @ady1
              Posted by ega on 01/07/2021 11:17:28:
              Good luck!
              Use an old mobile phone and film any complicated work you do so you can review it if required
              #552083
              Dalboy
                @dalboy
                If you can see an equivalent model on the Axminster site they have instructions some with wiring diagrams
                #552106
                Malcolm Farrant
                  many thanks for all the replies.
                  On the Machine there is a label stating :- SIP No. 01444
                  Does that help.
                  I agree I was just NOt careful enough when I took the old swich off.
                  I will have a look at the Axminster site for posible help.
                  I live just ouside Bristol, but do not know anyone who wight be able to assist me
                  #552114
                  Former Member
                    @formermember12892
                    #552152
                    DC31k
                      @dc31k
                      In case it helps anyone to help him, it appears that the 14" SIP bandsaw with the above number is a WOOD cutting bandsaw.
                      For reference: https://www.youtube.com/watch?v=qFjKMiu1P6c
                      https://www.dbkeighley.co.uk/masters/sip_01444_14_bandsaw.htm
                      Edit: it looks to be the same as the JET 14SFX model, for which there is a manual with wiring diagram here:
                      http://go.rockler.com/tech/Jet-14-inch-Bandsaw-manual.pdf
                      Reference pictures for comparison:
                      JET® 14-in. SFX Band Saw
                      https://www.toolden.co.uk/power-tools/bandsaws/sip-01444-14-professional-heavy-duty-wood-bandsaw-1500w-230v/
                      Edited By DC31k on 01/07/2021 19:24:16
                      #552851
                      Malcolm Farrant
                        Good morning to everyone. I hope the following may enable someone to be able to assist me. Everybody has been, as always so helpful.
                        • 4 spade terminals poking out of hole where the switch is to go and a switch with 4 terminals…
                        • it looks like it is simply a matter of pushing the spades onto the terminals, BUT
                        • the live feed is fed off into the heart of the machine and then returns to the switch, so when the switch is OFF, something within the machine is live???
                        In pictures:
                        • the DKLD DZ-6-2 [240v] switch has connections 3,4, 7 and 8 as follows:
                        #552852
                        Malcolm Farrant
                          I have tried to send suitable photos, but the sie tells me all are much too long !!
                          Thanks
                          Malcolm
                          #552854
                          not done it yet
                            @notdoneityet
                            Malcolm,
                            Shorten them? If not directly on your photo storage, you can likely load them to an email, which will almost certainly offer options on file size. Once done, copy and paste to your album.
                            Edited By not done it yet on 06/07/2021 11:13:12
                            #552880
                            Former Member
                              @formermember12892
