Hi All,
Sorry for the delay in letting all those who helped know how I got on.
The controller I settled on was a Series 9000 Vector Frequency Controller
After paying the motor supplier to install the cable between the controller and the motor, I installed the motor in the cabinet under the lathe (a real PIA) and was in the process of mounting the controller when the cable came out of the gland. I got in touch with the motor supplier and after we had passed through the “Well I've done hundreds of these and nobody's complained before!” phase it transpired that they had used glands designed for armoured cable rather than screened cable. So, (mutter, mutter) back under the lathe again to get the motor out and back to the supplier. The proper glands gave much more secure connections.
After the motor was reinstalled and the controller mounted, I started using the system and came across a couple of problems which centred on the motor deceleration time. The motor supplier had set this at 6 seconds which he said was standard for lathes as too short a time could result in the controller being burnt out.
The first problem I encountered was during threading. My usual practice is to cut a 3mm wide groove with a depth equal to the root diameter of the thread at the end of the thread. The tool is then run into the groove, the motor stopped, the tool withdrawn and then returned to the start point by running the motor in reverse. The half nuts remain engaged throughout. The delay between switching off the motor and the tool actually stopping, made it difficult to get it to stop in the groove. The lathe has an 8TPI lead screw and a Norton gearbox to cut imperial threads and a range of metric threads can be cut employing change gears. I didn't have a thread dial indicator with the lathe however I managed to make one which meant I could disengage the half nuts at the end of each cut which stopped the tool dead. So that was one problem sorted.
The second problem with the delay between pressing the STOP button and the lathe actually stopping is safety. If I get into trouble and press STOP, there will be a period of continued operation. It will be worse than a lathe continuing to rotate due to momentum as I suspect the ramp down period will be under power and will overcome the force produced as I am wound into the work.
The STOP button on the controller is a fairly small target to hit if you're in a hurry and I would like to install a larger STOP button. I presume this can be achieved by utilising a pair of the analogue input terminals and a switch but I can't make head or tail of the Manual. Can anyone help me with some advice regarding this?
After all this negativity, there are some aspects of the VFD that I like.
The ramp up time gives a very gentle start which is particularly good if the work has some weight.
I can do threading at 100rpm without having to engage the backgear.
When parting off, it is useful to be able to change the speed to get away from a resonant frequency if chattering becomes a problem.
The VFD reduces the number of pulley changes required which, given that they involve kneeling on the ground and fumbling around in the cabinet under the lathe is much appreciated.
On balance, given the hassles I had getting the VFD up and running and the safety concerns, I'm not sure if I would install a VFD and a 3 phase motor rather than a single phase motor and a reversing switch if I had the time over again. I suspect not.
This is the second time I have written this. The first time I made the mistake of trying to create an album of pictures to go with the words. When I returned to the post it had – of course – disappeared. I'm not making the same mistake again.
Alan C.
