Posted by Nick Grant on 04/03/2015 16:11:48:
Posted by Bikepete on 04/03/2015 15:58:21:
Congrats on the drill. Does the original 3 phase motor nameplate say something like 240/380V on it anywhere? If so powering it by inverter is the way to go for smoothness… with the bonus of variable speed so fewer belt changes…
Its a 380/440 brook crompton motor. I was under the impression you lost a lot of power with an inverter? Im more at home with mechanicals and paintwork than electrical so forgive my ignorance.
Mmm, despite having initially suggested it and despite the many benefits of inverters (very efficient BTW, high nineties percent – you may have been thinking of static or rotary converters which are less so) IMO there may be a good argument here to come to an arrangement with John who has a suitable single phase motor to swap.
First, if your motor is 380/440V, it won't run properly off a straightforward mains-powered (240V in, 240V out) inverter. There are ways round this from the complex (inverters with built-in voltage step-up exist, or you could use a step-up transformer then a 380V in, 380V out inverter, or even fiddle around with the motor's internal wiring to reconfigure it for 240V) to the simple (get a replacement 240V three phase motor) but either way it is hundreds of pounds of expense more than just swapping to a single phase motor.
Secondly, if you're not at home with electrics but go the inverter route anyway you could be fiddling around a fair bit before you have a working drill…could be a fun challenge/project of course if you're up for it.
Otherwise, unless the cost of a three phase package (various suppliers do them, safely pre-wired) isn't an obstacle, I'd consider going single phase initially, get the thing going, but read up on inverters etc and watch Ebay for motor and inverter bargains, with a view to converting to three phase yourself in due course.
We may wax lyrical about the benefits of three phase but a single phase drill is perfectly serviceable and the Fobco should be a joy to use however it's powered IMO.
