I have a single phase induction motor that I would like to put to use.
The motor is wired with 6 leads. I have probed with a multimeter and found the following:
White, red and yellow appear to be the motor winding connections (2, 4 and 9). The windings measure about 115R each.
The two brown leads are connected together (about 1R6). They are electrically isolated from the other leads. I presume the two brown leads are connection 1 "c/out". Could anyone suggest how these two leads are used? I did wonder if it was "count out" but I've turned the motor over and the resistance does not change. Maybe a thermal trip?
Many thanks,
