Posted by King Olaf on 23/07/2022 00:20:46:
I've heard people stuffing the pipe with salt or sand to prevent kinking then wrapping around a cylinder.
Before pipe-benders were invented that was how it was done, but skilled work. The tighter the bend, the harder it gets.
The trick is to support the pipe internally by stuffing it, or by bending it with and around fitting shaped rollers.
Cerobend is more supportive than salt or sand because it's incompressible. Water in a completely sealed pipe might work, but the seal would have to be strong.
I tried sand in 15mm copper pipe once: didn't go well. A bought bending spring worked better, but the result was adequate rather than well done. I didn't practice.
