Simple model engine solenoid powered
Home Forums Miscellaneous models Simple model engine solenoid powered
  • #694256
    John Mellor 1
      @johnmellor1
      20231126_20405320231126_20410420231126_20411920231126_20413920231126_204210
      John Mellor 1
        @johnmellor1
        It would be interesting to find out the original designer of this engine.
        #694271
          I don’t recognise it … but, in a similar spirit this radial five is brilliant:
          https://youtu.be/jeHNMjBrvLk?feature=shared
          Sorry, can’t figure how to embed video
          #694295
            At first I was thinking why have the conrod so far from the crank as the overhang can’t be good for smooth running then I noticed the swivel arrangement which is an interesting way to get over the need for cross heads or an oscillating “cylinder”
            Again, not one I have seen before
            #694300
              Thanks for embedding the video for me, Jason
                Looking for the Solenoid … DuckDuckGo found this:
                source Right
                but I would strongly advise NOT using the illustrated TSTHK web link
                Edit: __ This appears to be O.K. but is incomprehensible to me
                https://www.gkzhan.com/chanpin/0_p0/
                #694312
                  John Mellor 1
                    @johnmellor1
                    Thank you Michael for the interesting radial engine.  The links did not help me much but thank you for trying.
                    Yes, Jason, an interesting wiggle movement from the connection to the crank. Utilising a degree of movement… the twist of a piston in the cylinder… is clever.  Hence my desire to track down the designer and original article.
                  Home Forums Miscellaneous models Topics
