This could work and if the bearings are a problem, add some extra.
I have checked the reviews and all seems very good except this remark:
For the price this is excellent, works as intended, perfectly balanced motor. However you should know what you're doing as the power supply is a bit unsafe as there is no isolation between AC and DC side. I suggest you mount it in a grounded box sharing common ground with the potentiometer. But hey, it works and the safety concern is not in how it's constructed but the lack of instructions for novices.
If this is true, it could be really unsafe!!!!!!
This also means, there can't be a CE certification.
The CE certification on the supplied link is for a brushless DC motor and that can't be this 2 wire motor!!!!
According to the data sheet, the motor voltage is 100V DC, so be carefull.
Edited By Huub on 24/03/2022 22:12:39
