This cure may apply to many digital micrometers.
A little while ago I needed to photograph a digital micrometer being used with a length standard. The display wasn't, so to speak, and a battery replacement didn't cure this. I had previously noticed it looking faint so I suspected the 'zebra block', a strip of synthetic rubber with conductive stripes that takes the signals from PCB to display.
Dis-assembly was simple, remove battery cover and cell, remove the blanking plug from the data port and unscrew the display cover and. The electronics lift out but are linked to the spindle sensor by a delicate flexible strip. With care undo the clamp strip screw and separate the display from the strip. I used a PH000 scewdriver.
It's now possible to remove all the screws from the plastic frame and separate the display, frame and control board. There's also a flexible insert (with conductive pads) for the switches and the 'zebra strip'.
It was immediately clear that a cheap battery had leaked slightly causing a small patch of corrosion that affected the contact for the zebra strip and one switch. I cleaned this off very carefully using a piece of kitchen towel and meths, being very careful not to damage the underlying copper. I also cleaned both sides of the zebra strip the same way.
It was a fiddle to get the flexible strip back in position, but on reassembly, everything worked fine.
This is not the first device with a dodgy display I have fixed by cleaning the zebra strip, but do be sure it isn't a duff battery or dodgy battery contacts first!
On a similar note, a digital caliper showing unstable or slightly 'off' readings may well be cured by cleaning the scale with meths. I think the problem could be poor electrical contact between the wipers in the read head and the body of the scale.
