Simat 101 lathe for brass watch tools
Home Forums General Questions Simat 101 lathe for brass watch tools
  • #638369
    jon man
      @jonman64714
      Hi, i'd like to have a go at making some brass watch mainspring winders that range in size from 19mm outside diameter down to 5.3mm. The winders have a brass body with a steel plunger, i'm not a watchmaker i't's an hobby that i took up that's lead me here to start making my own tools.
      Will a simat 101 be capable of making these, i can't find any info on what size round bar the chuck on the simat 101 will hold, are parts and tools available for old English mini lathes.
      I've never used a lathe before, i've only used hand tools like tap and die set, bench drill etc, is the simat a good intro for a novice, what would expect to pay for for a well used simat 101.
      Are there any simat 101 owners on the forum, what do you think of it and what should i look out for when i go to view it.
      Thanks
      jon man
        @jonman64714
        #638380
        James Alford
          @jamesalford67616
          I have a Flexispeed Meteor 2 which is the predecessor of the Simat. Mine was second hand and the main things on it were the casting that holds in the back-gear had cracked by being over-tightened. I understand that it is a common problem, but causes no difficulties in use: well, mine doesn't. The other thing that needed to be adjusted was the headstock bearing which is just a phospher bronze bush. Mine needed a slight tweak, but was nothing of concern. Other than that, everything was sound.
          I am no great machinist, but it seems to be capable of working to tight tolerances, as long as everything is adjusted well, the tool is sharp and I don't try rushing.
          Did you mean the largest or smallest stock that the chuck can hold? I have the original Flexispeed chuck, so could check the capacity this evening.
          James.
          #638381
          jon man
            @jonman64714
            James, the largest stock the chuck can hold, the largest diameter part is 19mm so i am assuming i will start with a 20mm round brass bar, will it hold a 20mm round bar.
            Thanks
            #638399
            Iain Downs
              @iaindowns78295
              before you go to this effort, you might check out the 3D printed mainspring winders. If you have a 3D printer (or a mate with one) it will potentially save you a lot of time and money.
              here on you tube and the original discussion here.
              I have made some mainspring winders on my lathe (a standard chinese 7×14) and it was easy enough. The only thing you need real accuracy for is the arbor. In a Bergeon, the arbor has a hook built in. That's quite hard to machine at that scale.
              Just before I discovered the 3D printed mainspring winder I bought a set of chinese winders – 10 of them (for about 50 quid). Naturally, none of them were the right size for the particular mainsprings I wanted to wind. All of these had no hook, just a friction fit arbor. This is also the approach I'd taken on the two I'd hand made and one worked OK and one didn't. I think you need to get the diameter of the arbor just right – a fraction too small and it won't wind a bit to big and there is the risk of breaking it – especially if it's an old old spring.
              I've actually printed a winder for the watch I'm looking at at the moment, but this was very recently and I've not got round to trying them out yet – it's on my list. However, I have quite high hopes for them and it may be worth you investigating. They have some quite clever ideas behind them. Worth cheching out.
              Iain
              #638413
              peak4
                @peak4
                Hello and welcome Jon;
                Yes I do have a Simat 101, which I bought from new, though it's currently out of commission in a box under the bench.
                I bought it with the standard 3 jaw scroll chuck, and a Pratt Burnard 4 jaw independent.
                The through hole in the chuck for the 3 jaw is about 13.6mm, and 15.7mm for the 4 jaw. Clearly the through hole through the spindle is a lot smaller.
                Yes you can hold a 20mm bar, and turn it OK, but be careful not to strain the jaws, or chip a tooth off the scroll chuck jaws; tailstock support would seem prudent.
                Bill
                #638419
                Bazyle
                  @bazyle
                  When buying make sure the 3 jaw chuck has both sets of jaws, or reversible ones as you will want 'oustide jaws' for holding larger parts.
                  A small lathe like this is a good idea for learning on and safer. Far too many come on here, albeit usually wanting to make their motorbike bits, having bought a lathe with a 1 or 2 horse power motor not realising how dangerous it can be when you haven't a clue.
                  #638427
                  jon man
                    @jonman64714
                    Thanks for the replies, when i go view it i'll make sure it as both sets of jaws or reversable ones, when i spoke to the seller he didn't know that much about it as it belonged to his dad, he did tell me it did have a 6mm chuck, i think this probably the tailstock chuck, from reading the info sheet link above it has a 0 morse taper.
                    I've googled 0 mt morse taper chucks to see if i can get one that can take a larger drill bit than 6mm, they don't seem to be available the part as a 6.6mm centre bore, is it possibe to turn down the taper on a 1mt or 2mt to fit 0 morse as the chuck on these are 13mm.
                    I'd seen the 3d printed winders but wasn't sure if they'd work that well, then i came across this write up on making a copy of the brass bergeon winders it as the dimensions of winders from 00 to 15, my attention went from printing a 3d one to making a brass winder like the one in this link  **LINK**
                    I'm going to view it tomorrow evening so i've been trying to swat up before i go, it's a big learning curve.
                    Thanks
                    Edited By jon man on 20/03/2023 13:08:09
                    Edited By jon man on 20/03/2023 13:24:42
                    #638429
                    peak4
                      @peak4
                      It's good to have the drill cuck and relevant arbor, since, whilst it's a 0MT, it's a truncated one.
                      As I recall, and I may be wrong, it's the wide end of the 0MT which is missing, so it's not just a case of getting a full length one and sawing off the thin end.
                      There's some info on Tony's site HERE
                      http://www.lathes.co.uk/flexy/page5.html
                      Bill
                      #638465
                      Jim Guthrie
                        @jimguthrie82658
                        Posted by jon man on 20/03/2023 12:58:26:
                        I don't think I would try a larger Jacobs style chuck on the Simat than the one provided. I have a Cowells 90ME which is the present day version of the Flexispeed/Simat family and I doubt if the short 0MT taper arbor could handle any drill appreciably larger than 6mm diameter without slipping.
                        Cowells supply short 0MT centres if you need them
                        http://www.cowells.com/pricelist.htm
                        and they also supply a 6mm capacity Jacobs style chuck complete with the short 0MT arbor so you might be able to get them to supply the arbor separately but I suspect that the Jacobs taper would be too small for a larger chuck.
                        Jim.
                        Edited By Jim Guthrie on 20/03/2023 17:15:38
                        #638481
                        Bazyle
                          @bazyle
                          You won't really be able to drill bigger than 6mm anyway but don't worry you will learn how to bore out bigger holes.
                          Having looked at the 3D print video I think it is all easily within the capabilities of a Simat to make a brass equivalent. The difficult operation would be the tiny hole for the spring holder but as a watchmaker you probably can take thatin your stride.
                          The Bergeon one is also doable with more fuss except perhaps for the long knurled body which will need practice first. I suggest a compromise here with a bit of rubber tube.
                          Interesting to see this area of work I am not familiar with.
                          #638690
                          jon man
                            @jonman64714
                            I went yesterday to have a look at the lathe, it wasn't in working condition, i couldn't move the saddle, apron the handles would not turn, i tried to move the tailstock, it moved but not smooth, it looked really well used or abused.
                            It was a nice size not too big and not small it would have been perfect for me, glad i did my research before going on what to check when looking at one. i will keep my eyes peeled for one of a similar size in working condition that may just need a clean, i've started looking at the online auctions, something may come up.
