Silver steel gudgeon pin ?
Home Forums I/C Engines Silver steel gudgeon pin ?
  • #2330
    RICHARD GREEN 2
      @richardgreen2
      RICHARD GREEN 2
        @richardgreen2
        Hello all,
        I am restoring a vintage 5 hp Petter m type engine built in 1922, I have done an extensive overhaul including , new cyl liner, white metal main bearings, piston rings,reground crank,little end bearing etc,etc.
        I have to make a new gudgeon pin, do you think a nice piece of silver steel would be OK, or should I use something like EN16, the diameter is 1",
        I have a piece of silver steel that fits the piston perfectly, a nice push fit, and the last inch taps home nicely with a soft hammer, so it would be nice to use it if possible,
        What do you all think ?
        Richard.
        #87099
        martin perman 1
          @martinperman1
          Richard,
          If you contact Roland Craven
          Roland Craven
          E-mail Address(es):
          roland@petternut.co.uk
          He will help you, he is in the stationary engine world the Petter expert.
          Martin P
        Home Forums I/C Engines Topics
