Thanks to you all for your replies, even the allegorical culinary tales!
Phil H……I tend to follow the specs and dimensions that are called for on the drawings because it's a habit of a lifetime of aircraft engineering. Although in this instance I have already departed from that by fabricating the axleboxes from steel seeing little rationale in using expensive gunmetal castings and then fitting a bearing, these steel items have cost 1/10 of the castings.
Dave Wooton……. The locomotive is indeed the KS Moodie design and I've had a good read of the Helen Longish build, and particularly note the testing recorded on page 11. Judging by those results, I'll certainly not bother myself with the hastle of trying to heat treat and produce a distortion free set of axles, I very much doubt that I'll get it to run 1000 miles let alone 3000+!!! In fact there'll be a good celebration after the first mile.
As this is the first and will almost certainly be the only locomotive that I shall ever build my inclination is to follow 'expert' advice and so when I read in the well known Martin Evans loco building book where he stated that ' there's no advantage to be gained by using Silver Steel', I thought that I'd ask what others think. Assuming equally accurately ground samples of mild steel and silver steel I am of the opinion that the latter has the harder surface in the normal, untreated condition.
Regarding oilite bushes why would these be more prone to ash damage than the common solid gunmetal casting, indeed, a needle roller will require a dust shield to prevent grit getting in. As an example, the BMW K75 bike has a common seizure of the clutch operating shaft which is mounted on needle rollers and gets exposure to water grit and crud thrown out from the resr tyre. I've owned 3 and they all needed replacing, a simple but time consuming job.
Once again thanks to all.
Trevor.
