Posted by Chris Gill on 16/02/2023 21:39:56:
I encountered a bit of a puzzle when silver soldering recently and I wondered if anyone could advise.
I was trying to solder brass valve chests onto steel cylinders (EN1 or EN3, not Pb) for a model I was tinkering with. I cleaned everything, applied flux and heated inside the cylinder primarily.
I picked the finished item in dilute citric acid for a short time. All the cylinders had a black coating on the inside and I assumed it was just a little oxidation but wet-and-dry paper wouldn't touch it.
Then a little bit flaked off and I discovered it was a thick, glass-like glaze. After a few experiments I found I could turn the glaze off using carbide tools but HSS didn't seem happy.
Any idea what the glaze might have been?
In terms of the model, there were several other "lessons learned" so it runs off a small motor rather than air or steam!
if the flux is not thoroughly cleaned off, it can react with the citric acid and form a glass-like glaze on the surface of the metal. This residue can be difficult to remove, especially if it has been allowed to sit for a long period of time.
To prevent this issue in the future, it's important to make sure that all flux is thoroughly cleaned off after the soldering process is complete. You can try using a wire brush or sandpaper to remove the residue, or you may need to use a more aggressive cleaning agent to dissolve the glaze.
It's also possible that the glaze could be a byproduct of the citric acid reacting with the brass or steel. However, this seems less likely given that you were able to remove the glaze with carbide tools.
