Silver Soldering Long Sections
Home Forums Workshop Techniques Silver Soldering Long Sections
  • #286607
    Richard Fryer
      @richardfryer15257
      Good afternoon everyone,
      I hope so of you will be able to help me, with my silver soldering task.
      I am restoring a second world war Scammell Pioneer heavy recovery tractor, part of which is making a whole new windscreen frame from scratch.
      I have welded up the 25mm x 25mm angle outer frame, but now I need to do two things:
      Firstly, i need to solder some 1/2" x 1/2" brass channel into the bottom of the frame to hold a 6" deep pane of glass.
      Secondly, I need to make the hinging inner frames from the same 1/2" x 1/2" brass channel.
      I suspect the first task will be the most problematic, given that it involves long joints between dissimilar metals. I imagine I need to do it at as low a temperature as possible.
      So, I have a few questions:
      1) what solder and flux do you recommend?
      2) Is the long joint between the brass channel and steel angle going to be possible / a nightmare / very problematic?
      3) I'm assuming silver soldering is the best bet, but open to suggestions of other processes.
      4) Does anyone want to come help? in somerset.
      5) Any other advice / pointers / things to look out for etc.
      Thankyou in advance for any help you can lend.
      Richard Fryer
      Richard Fryer
        @richardfryer15257
        #286609
          Hello Richard,
          You may be better off getting someone to TIG it for you?
          How were the originals made?
          peak4
            @peak4
            Wouldn't there be an issue with differing expansion rates, between steel and brass, causing distortion?
            Neil, Can you TIG dissimilar metals?
            #286614
            Ian P
              @ianp
              Would love to help but distance rules it out.
              Certainly silver soldering would be best for the frame made of brass channel. I presume the the corners would just be plain 45 degree mitre butt joints without any overlaps or stiffening.
              I too think a long brass to steel soldered joint would be problematic, it would be easy to end up with a curve. Why not just drill and tap the steel angle at regular intervals and fix the channel to it with screws in slightly slotted holes. The screws would be hidden by the rubber strip or whatever holds the glass in place.
              Ian P
              #286616
                For 10ft of material over 100deg F temp change you would get about 1/32" difference in movement between brass and steel so say each half of your screen is 2ft long so maybe 0.006" so unlikely to see much distortion on the finished frame.
                If silver soldering it I would start heating in the middle and chase the solder as it melts towards one end, then come back and chase it from the centre out to the other edge that way you keep the amount of movement during the higher soldering temperatures in one spot rather than trying to heat the whole 2ft length. I've done similar when soldering rings around the outside of discs with a similar circumference to your screen length.
                Use Tenacity No5 solder sometimes sold as just "HT" as this will stay active for longer and the lowest melting point silver solder you can get.
                Edited By JasonB on 01/03/2017 14:54:36
                #286617
                Scrumpy
                  @scrumpy
                  Have you thought about pop rivets first then either silver solder or possible a high melting soft solder using the stitch method
                  #286625
                  Speedy Builder5
                    @speedybuilder5
                    If you are worried about distortion on cooling, perhaps put a slight bow in the steel before you silver solder so that it would straighten on cooling. Also, use step soldering; i.e.. solder a few inches, let it cool, miss a few inches and then solder some more. Once you have a series of steps, return and fill in the gaps.
                    However I would use lead solder if I could get away with it.
                    BobH
                    #286638
                    not done it yet
                      @notdoneityet
                      Glue it? Its not going to war any more, after all.
                      #286650
                        I was thinking that tig as a heat source for a compatible filler, which could be silver solder. the advantage with TIG being you could stitch it at intervals along the length, then fill in between (if required) to minimise distortion. I suppose you could do the same with an oxy actylene or oxy propane torch.
                        Keith Hale
                          @keithhale68713
                          Hello Richard
                          Soft solder it with 60/40 tin lead soft solder> Melts at 187 deg
                          25% of the distortion problem compared to silversolder.
                          Joint strength I suspect will be adequate.
                          This is one of those occasions when silver solder is not the answer!
                          http://www.cupalloys.co.uk/soft-solders/
                          Keith
                          Edited By CuP Alloys 1 on 01/03/2017 20:45:17
                          #286683
                          vintagengineer
                            @vintagengineer
                            I would clean both parts and tin using solder paint. Then clamp it all up and soft solder the lot. I expect that was how the original was done. Don't worry about the strength of the joint being weak. Bugatti used to soft solder their propshafts together.
                            Its all based on the surface are of the joint.
                            #286699
                            Andy Ash
                              @andyash24902
                              Posted by Neil Wyatt on 01/03/2017 18:47:52:
                              I reckon you're on the right track with that, but I've never made silver solder work with TIG. It's a bit expensive to be making a mess with silver solder anyway. I think the contamination issues and the low temperature of silver solder reflow would be the reasons. The trouble I find, is that I can't get silver solder close enough to the arc. If I lower the arc energy, then the steel isn't hot enough to accept the solder.
                              Silicon bronze (SIF do a good Silicon Bronze), is the route here I think.
                              Silicon bronze TIG brazing wouldn't be so susceptible to contamination as Silver solder would be.
                              I've never tried this particular combination but I might give it a go and report back.
                              I would offer to help but it's a bit distant and I imagine my skills would probably let me down anyway.
                              I imagine they would have used a special fluxed brazing spelter and an oxy torch back in the day.
                              Edited By Andy Ash on 01/03/2017 23:58:16
                              #286707
                              Keith Hale
                                @keithhale68713
                                You weld with TIG. You do not braze.
                                They are two totally different processes. Silver soldering is just one facet of the brazing process that is dependent on capillary flow to effect a joint. Heat from a TIG torch is more intense than oxy-acetylene, It is highly unlikely that you will be able to generate the heat in the right places to make a successful joint. It is bad enough with oxy-acetylene. This is the main reason model engineers have joint problems. At best you will simply melt the silver solder on top of the joint leaving a crack underneath!
                                You are not brazing You are not welding. You are simply using an expensive rod to block a hole! Probably the reason Andy didn't make it work.
                                48 years in this business and I've never seen TIG as a heat source for brazing work either! I can't even recall it being attempted.
                                It has nothing to do with contamination, nor the alloy used – special or not. Joints attempted using TIG will be inferior if made at all,
                                Going back to the original question, if there is still too much distortion when using tin-lead paint/paste/wire then glue it!
                                Keith
                                #286709
                                  Keith, one of our motorcycle building members has shown TIG brazing in the past and very nice it was too. This is an example of the sort of thing. They tend to leave the weld textured rather than dress it as is common with fillet brazing done with a torch
                                  Edited By JasonB on 02/03/2017 07:43:58
                                  #286710
                                    Posted by CuP Alloys 1 on 02/03/2017 07:19:12:
                                    +1
                                    That's almost certainly what a modern vehicle manufactirer would do.
                                    … I have no experience of specific adhesives for the job, but it I think it would be worth you [Richard] investigating.
                                    Alan Waddington 2
                                      @alanwaddington2
                                      I would consider bonding it on with sikaflex automotive windscreen adhesive. Key and degrease both surfaces and use the appropriate sikaflex primer.
                                      #286712
                                        Posted by peak4 on 01/03/2017 14:03:35:
                                        Edited By JasonB on 02/03/2017 08:10:23
                                        #286715
                                        nigel jones 5
                                          @nigeljones5
                                          Hi Keith – good to chat with you at the show in Oldham, I even managed to sell one of my delux boilers there so a success for me. I have used TIG as a heat source for silver soldering copper and its not a great process. The heat is too localised and you cant see what you are doing with the rod. Ive also welded brass to steel with the tig, you get a good result but even with the right rod I found the joints to be quite brittle. If it were my job id be inclined as others have indicated and soft solder it. Best of luck Richard.
                                          #286721
                                          Ian S C
                                            @iansc
                                            For a military vehicle like that I'd tend to think that it would have been riveted after soft soldering. Tin both surfaces, then use brass rivets, heat with a torch/blow lamp.
                                            Ian S C
                                            #286724
                                            Ian P
                                              @ianp
                                              WHY DO WE DO IT?
                                              24 hours have not yet elapsed since Richard made the original post and asked several questions. There have now been about twenty replies covering lots of options and presumably there may be many more. Unless Richard comes back with some feedback (I think unlikely, with only one other posting in four years) what is the point in 'us' (me included) speculating and pontificating?
                                              Actually all the replies do have a useful purpose in that it is good engineering discussion and may help spread useful tips. In the past some of these type of threads have run and run withe no real purpose though. OK it does no harm but as it increases website traffic so the adverts get seen more.
                                              Ian P
                                              #286741
                                              Cornish Jack
                                                @cornishjack
                                                Nothing whatsoever to add to the technical content, but back in the 50s I was stuck at Sharjah (in the Gulf) for several days and the local REME guy ('Shani' Wallis) offered me a ride with him in his Scammell to recover a Bedford 3 tonner stuck in the desert. What a BEAST!!! 6 wheel drive, 6 forward gears and we 'made' our own road through the sand dunes, climbing the steep sides as though they didn't exist! The recovery was sheer brute force – hook it up to the winch and pull it bodily out of the sand. We also used it to restack some 1000 lb bombs by rigging a 'derrick' with a long pole and the winch.
                                                Apologies to Ian but nostalgia can overwhelm at times!!blush
                                                rgds
                                                Bill
                                                #286751
                                                Samsaranda
                                                  @samsaranda
                                                  Hi Cornish Jack, I served at Sharjah bit later than you in the 60's, spent twelve months there on the airfield. A previous posting was spent on aircraft recovery and transport in the South of England, spent two and half years on that and we regularly used the Scammell Recovery Tractors, as you say quite a beast and very capable of winching a fully loaded Bedford with Queen Mary trailer across a totally waterlogged and very boggy field. Aircraft tend to crash in the most awkward of locations. I look back fondly on the many miles spent bouncing along the roads in the old Scammells.
                                                  #286754
                                                  Richard Fryer
                                                    @richardfryer15257
                                                    Good afternoon all,
                                                    Wow, I never expected such a huge response, thanks very much. Apologies for the delay, I'm fighting the man flu at the moment, and we all know how bad that is right?
                                                    Some brilliant responses chaps, let me see if I can provide some feedback.
                                                    Firstly it needs to be a watertight joint, so that rules out any riveting, screwing, stitch welding/soldering.
                                                    I have got a TIG welder, which I have been teaching myself to use and have got quite good on carbon steel. I spoke to the welding supplies chap I use for work about TIG brazing after watching a number of online videos on the subject, and he recommended SifSilCopper No. 968. I tried this on some scrap with pretty rubbish results. I found I was blowing straight through the brass before the steel was hot enough, and struggled to get the rod near the puddle before it melted. Plus it gets expensive trying to practice endlessly. The tricky thing with this opposed to TIG welding is that you don't melt the parent metal, so you have no idea if its hot enough until you add the rod, which I find just melts when it gets near the arc.
                                                    Originally the frame was all made of steel, but my dad in his infinite wisdom thought we should make the channels in brass, I'm beginning to think it was a bad choice. He's very good at coming up with "helpful ideas" but then it falls to me to make them reality.
                                                    I like the idea of soft soldering the steel – brass joint, which I gather works at a lower temp, and reserve the silver solder for the brass mitre joints.
                                                    Also I like the sound of Ian S C's idea about tinning the surfaces, clamping them together and then just running the torch along.
                                                    For the benefit of the last two posters, I suspect you are referring to a Scammell Explorer since you mentioned it was 6×6, mine is a Pioneer, the wartime predecessor to the Explorer which was 6×4, but a capable beast none the less.
                                                    Thanks again chaps, and I look forward to your replys. Richard
