I'm in the process of designing the starting valve for my traction engines, based on fullsize. For those parts not in contact with steam I plan to use brass. But the body, which will be in contact with full pressure (wet) steam ideally needs to be bronze. The body will need to be silver soldered together from several smaller parts.
I've recently silver soldered some PB102 bronze with some success, but it's a right pain to machine. I've also machined some LG2 gunmetal with excellent results. The starting valve body is going to need some accurate and burr free internal machining, so I'd prefer to use LG2.
But LG2 contains lead, so the question is how does it silver solder? I've found a thread on this forum, from a while back, where it was said to silver solder well. But the internet seems to be confused on the subject. Some commercial organisations says it solders well, but is less good for brazing. I take soldering to mean relatively low temperature with tin/lead solder, whereas brazing includes silver soldering.
What does the collective think?
