Silver soldering a previously soft soldered boiler
Home Forums General Questions Silver soldering a previously soft soldered boiler
  • #446737
    Former Member
      @formermember19781
      Former Member
        @formermember19781
        #446812
          Less of an issue in your case where you were able to take the small boiler apart and ensure all traces of soft solder were removed.
          It is not so easy on a larger assembled boiler where someone has tried to caulk a leak with soft solder and then tried a silver solder repair especially if it's in the firebox. The soft solder may well have flowed into the joint and no amount of scrubbing will be able to remove it so when you start to silver solder the lead boils and the gasses weaken the new silver solder joint.
          #446814
          Former Member
            @formermember19781
            #446817
            old mart
              @oldmart
              Removing all traces of the soft solder is the key, I cannot fault your procedure. Residual traces of the soft solder would have been visible after the pickle bath.
              #446985
              nigel jones 5
                @nigeljones5
                Whilst its not something I would do on a complete boiler…..if the silver solder has clearly taken to both surfaces (and it is obvious when it hasnt) then the joint should be sound. I have removed soft solder from joints and re-soldered with silver solder, albeit on brass with no ill effect. If youve cleaned away the soft solder and used quality flux, rod and given it enough heat then all should be well. If it passes test at twice wp then you know its taken properly. As stated above, any soft solder would have turned a nasty, almost black colour after pickling and would stand out. Hope this helps.
                #446986
                Former Member
                  @formermember19781
