silver soldering
silver soldering
Home Forums Materials silver soldering
  • #263775
    Christopher Griffin
      @christophergriffin65256
      I bought the missus a silver plated samovar, whilst cleaning it i dropped it! Breaking off the tap and snuffer hinge. The noise of me dropping it was bad enough but the
      noise from the missus has been considerably more. Can any one tell me where i can get some silver solder local to Downham Market please!!.
      Christopher Griffin
        source of silver solder
        #263866
        Brian H
          @brianh50089
          Do you know what the metal is under the silver plate?
          Silver solder is generally for quite high temperature brazing and may not be suitable.
          #263868
          nigel jones 5
            @nigeljones5
            dont go anywhere near it with silver solder or you will surely destroy the lot! Im assuming its for ornamental purposes and not a rare antique, in which case it needs glueing back together – use JB weld. Otherwise it will require expensive professional jewellery repair.
            #263869
            JohnF
              @johnf59703
              Christopher, silver soldering will certainly destroy any silver plate, personally I would use tin solder, not tinmans which is generally 60/40 tin/lead–use tin. You can get this at any plumbers merchant all you need is lead free plumbers solder, not pure tin but close enough. My guess the base metal will be copper or brass ?
              I would also avoid the plumber flux this is quite aggressive better to use a resin flux and wash of as soon as you have completed the job.
              just my thoughts cheers John
              #263870
              martin perman 1
                @martinperman1
                Christopher,
                I have a 1930's beer mug made from stainless and I knocked the handle off, rather than ruin the highly polished finish I decide to araldite it and its been a success.
                Martin P
                #263877
                Speedy Builder5
                  @speedybuilder5
                  To soft solder stainless steel, use phosphoric acid (jenolite) as a flux, ordinary tin / lead solder and wash off afterwards.
                  #263918
                  Keith Hale
                    @keithhale68713
                    Hi Chris.
                    Silver soldering will destroy the silver plating. You have two options.
                    Glue it on or
                    use soft solder.
                    To maintain the appearance, use an alloy that gives a good colour match on the silver plate. Ordinary tin-lead solders will produce a grey/black joint. Use a silver tin alloy, 2207, that melts at 225 deg C. It is readily available as a flux cored wire in 1m lengths. It can be posted to you ex stock for £5.39. You don't even have to leave the house!
                    http://www.cupalloys.co.uk/soft-solders/
                    What the eye can't see ……………..!
                    PS It works equally well on stainless steel.
                    Edited By CuP Alloys 1 on 31/10/2016 08:51:07
                    Edited By CuP Alloys 1 on 31/10/2016 08:54:47
                    Edited By CuP Alloys 1 on 31/10/2016 08:57:28
                    #263920
                    JA
                      @ja
                      Is the samovar of any value? If not glue it with an epoxy. If it is get advice from a professional jeweller. Silver solder is a no-no for the reasons already given. Glue will work but how do you remove it when the next repair has to be made? Low temperature solder, lead/tin etc, is the correct repair but probably requires quite a lot of skill to get it right.
                      JA
                      #264507
                      Christopher Griffin
                        Thank you for all the advice. Job done!. Complete success. Noise gone from other armchair!!
                      Home Forums Materials Topics
