When the cadmium is removed from the alloy there are two effects
1) the melting temperature increases (combatted by adding more silver and tin)
2) the molten alloy is less fluid
and in the case of easyflo2 an increase in the melting range from 10 to 30 deg C
So yes – it is different
Overcome these difficulties by
a) open your joint gaps to approx 0.15mm
b) consider putting a larger burner on your propane torch.
I suspect that oxy-acetylene has been used to create the extra heat. In using it the alloy is being overheated which is very easy to do. Overheating is the only way to produce porous joints.
Avoid overheating by watching the flux. When it becomes a colourless liquid you are approaching the melting point of the solder.
Do not heat the rod heat the joint. Let the rod get its heat from the joint not the flame. You might well find that a thinner rod helps you.
Remember what you are trying to do …… ie braze. Remember the principles and don't deviate from them. You will be successful. If necessary seek help from your alloy supplier.
Professional boiler makers now tell us that they prefer the cadmium free alloy. Because it is less free-flowing it is easier to control and they use less!
The days of boilers being assayed are numbered!
