F750. The 8 lbs didn’t include the bloody 2 2 x16 gauge rails that were forced on us by the rules, but were utterly useless in a monocoque. The 40 lbs did, and got there by very careful use of the rollover hoop, round not sq tube, and keeping it very thin, and the car very small. (Most of the body was less than the height of the wheels, and they were 20″ in dia) And virtually no brackets – just threaded tubes brazed (no nuts and centre drilled out allen bolts sized to a maximum stress loading.
Thats not a rolling chassis – thats a basic coffin/spaceframe – you have to put engine gearbox fuel tank etc etc.
1/2″ aerolam board – its a honeycomb of paper with very thin glass reinforced epoxy outers. You make it up in a series of diaphragm bulkheads – ie thick wall with big oval cutouts.Probably been superseded by something else now
40lbs Not F1 at all BTW. (And we were a lot smaller than even the present F1 cars) Easy to move about the workshop! Thats a steel spaceframe in 20g round steel tube. That wasn’t the lightest chassis about – one or two others were lighter, but at the expense of rigidity, so they didn’t handle so well. Which is why I went to the Aerolam board, and I lost quite a few lbs.
Keep the suspension bolts to 1/4″ dia, turn down the starter motor casing, ali flywheel, ali disks, magnesium wheels –
How heavy did you think a racing car was? Most of them, without an engine, you can easily pick up the chassis/monocoque even pretty well fitted out. – or could. I’m a bit out of date now.
