Silky smooth taps
Silky smooth taps
Home Forums The Tea Room Silky smooth taps
  • #307183
    Robin Graham
      @robingraham42208
      Not of the thread cutting variety, hence Tea Room. I've finally got round to installing a salvage yard sink in our bathroom. The taps which came with it were a bit croaky so I stripped them down, cleared the crud, and greased up the moving bits with Molyslip HSB, because thats what I have.When I reassembled them they were silky smooth, but then I thought – Duh – Molyslip for potentially potable water? What should I have used?
      Rob.
      Robin Graham
        @robingraham42208
        #307185
        Hopper
          @hopper
          Silicone grease. Or plumber's grease from the hardware store, which is usually either silicone grease or a vegetable base, such as castor etc.
          #307192
          Joseph Noci 1
            @josephnoci1
            Plain Simple Vaseline – non perfumed variety..
            #307200
            MichaelR
              @michaelr
              You can get Food Grade lubricants which will do the job, a search on the internet brings up suitable lubricants.
              Mike.
              #307201
              Danny M2Z
                @dannym2z
                This product could be of use (if you can obtain it locally). **LINK**
                It's Australian of course.
                * Danny M *
                Edited By Danny M2Z on 15/07/2017 09:28:20
                #307218
                larry Phelan
                  @larryphelan54019
                  As the man said " VASELINE", the stuff our mothers used to use for everything,from stuffed noses to cut knees and everything in between. Forget about silicone or molyslip and all the rest of it. Stick to good old Vaseline,great for putting on screws as well,they drive in a treat !
                  #307242
                  MW
                    @mw27036
                    Before I went upmarket with molislip, I used Vaseline as it was readily available, same tub still in the workshop, and like the guys say, it does the job, it probably would dry out before something like molislip would for long-term lubrication. Obviously I'd stay clear of molislip if it's going to come into contact with potable water.
                    I believe the old timers favourite was tallow, but where you'd get  that these days?
                    Michael W
                    Edited By Michael-w on 15/07/2017 13:39:13
                    #307243
                      Tallow is easy enough to buy, still often used for threading large steel pipes, most decent plumbers merchants will have it, Monument do it and probably other makes too
                      Edited By JasonB on 15/07/2017 13:42:26
                      #307258
                      KWIL
                        @kwil
                        As Hopper said the little tin of Silicon grease from the plumbers store is stated to be for potable water.
                        I would not use vaseline on anything that can rust, it absorbs water, I used to test the stuff which came in 36 gallon drums!
                        #307353
                        Robin Graham
                          @robingraham42208
                          Thanks for replies. Not sure why I used molyslip in the first place – stupidity I suppose. But it does work! Further investigation reveals that MoS2 is actually pretty innocuous – rodents feel poorly when fed 500mg/kg body weight daily, so that would be a couple of tablespoons of molyslip or more a day for me, so perhaps not really a problem. It seems excess Mo in the body results in copper deficiency, so maybe a Molyslip/Copaslip blend would be better wink.
                          Best to get it right though! Vaseline it'll be – though even that is not without hazard it seems. Intrigued to know what it actually is, I searched and came across a site with a homebrew recipe developed because Vaseline is – shock horror – a petroleum product. Smearing it on chapped lips is like drinking gasoline apparently. Good God! Nowt rummer than folk I suppose, think I'll risk it.
                          Thanks again for replies, Rob
                          Edited By Robin Graham on 15/07/2017 22:59:21
                          #307402
                          Gordon W
                            @gordonw
                            Our water is very acidic, taps don't last very long. I regularly have to dismantle and clean and polish them. I used copper grease (because I had some ) works very well and no ill effects after 25 yrs. the grease does not come into contact with the water.
                            #307723
                            Howard Lewis
                              @howardlewis46836
                              Strange; I use Vaseline as an alternative to mineral grease, in many cases. Including water taps (faucets as our North American friends call them), and have yet to feel even slightly poisoned.
                              For a lot of the time, I use Bacon fat on the other sort of Taps, can't be too far removed from tallow?
                              #307726
                              Martin Kyte
                                @martinkyte99762
                                Have you noticed your knees don't creak and your hip pain has gone and as for the constipation . . . .?
                                If so stick with the molyslip.
                                ;0)
                                Martin
                                #307757
                                Gordon W
                                  @gordonw
                                  I was told that Vaseline was first discovered by the old oil drillers in USA. The drill rods sometimes came up covered in a white grease and they used it on burns etc. So assume it is mineral based. Maybe one of our US readers know ?
                                  #307777
                                    Beware the warning above – Vaseline will make your taps rust
                                      Posted by Gordon W on 18/07/2017 16:35:55:
                                      It's just one of the heaviest of the petroleum fractions with LPG at the lightest end, than petrol, paraffin, petroleum jelly, than paraffin wax and ultimately ashphalt/tar.
                                      Mike Poole
                                        @mikepoole82104
                                        I used to use white petroleum jelly to lubricate the contacts of the drum controllers on travelling cranes, also useful for training people on laying adhesive on body panels by robot application. Just scrape it of the panel and recycle it on the next run, it behaves much like the adhesive or gap filler.
