Signature Files
Signature Files
  • #39085
    keithmart
      @keithmart
      keithmart
        @keithmart
        Hi
        Would it be possible to have signature files added to the forums. I am getting tired of adding:-
        Keith
        Leeds UK
        Thanks
        #47384
        Sub Mandrel
          @submandrel
          Seconded!
          Circlip
            @circlip
            Surprised that there is no post number on the individual replies, saves having reams of Quote passages.
              Regards  Ian.
            #47387
            Les Jones 1
              @lesjones1
              Hi Keith,
                                 You could just create a template file with Notepad with the text you have in your post. Save this file on the desktop (Or anywhere that suits.) When you are ready to post a message first open this text document, highlight all of it. (Put the curser at the start of the file, hold the left mouse key down and drag the curser to the end of the text and release the mouse key.) Now press control C on the keyboard. (This copies it to the past buffer.) Now put the curser in the post message box and press control V. This will put a copy of the template in the message box. Then just type the rest of the message.
              Les.
              #47393
              keithmart
                @keithmart
                Hi
                Thanks, but a proper siggy file would be better.
                Keith
                Leeds uk
                #47397
                John Stevenson 1
                  @johnstevenson1
                  If you are using Firefox look for an add on called WiseStamp.
                  It lets you select a few different signatures and insert them with a right click menu action, as below.
                  John Stevenson,
                  Nottingham,
                  UK.
                  #47402
                  Les Jones 1
                    @lesjones1
                    Hi John,
                                     Last night I tried to find a way to assign a text string to a hotkey or function key.
                    I did not find any suitable method.
                    I have just tried your suggestion and it works great. I did have some difficulty getting rid of the logo it was adding to the bottom line but leaving the user name box blank seemed to solve this.  This message was finished using your method.
                    Les
                    (Ormskirk Lancs.)
                    #47404
                    Donald Mitchell
                      @donaldmitchell68891
                      John,
                      Thank you for the tip re. Firefox WiseStamp, works great, very useful.
                      By the way John, my VMC table has no more oil holes in it – yet.
                      Donald Mitchell
                      Castle Douglas
                      Bonnie Scotland
